i use flaskmpeg to convert my vob files to mpeg2 using the svcd template.
would someone tell me where my "2 channel stereo" comes from when doing this conversion? is it pro-logic stereo or just plain old stereo?
also, does flask support dts in the same way?
thanks
THIS IS HARDCORE
If you are using FlaskMPEG, the audio will be in Dolby Surround, assuming that the source AC3 was in 5.1 or surround to begin with.
I don't think that FlaskMPEG can decode DTS audio.
Regards.
Michael Tam
w: Morsels of Evidence -
thanks!
after i posted i realized that i hadn't searched the site for the answer. i did, but still wasn't able to find the simple answer(yes/no) i was looking for. im sure you're sick of that question since it's been asked so many times
thanks again!
THIS IS HARDCORE
Dolby Pro Logic IIx encoder
By nateo200 in forum MacReplies: 4Last Post: 4th Feb 2012, 13:45 -
No Dolby Pro Logic from AC3Machine
By jonghyunchung in forum AudioReplies: 9Last Post: 28th Jan 2009, 14:35 -
Dolby Digital switching to Pro-Logic
By toneystone in forum AudioReplies: 4Last Post: 6th Jan 2009, 06:11 -
dvd audio and pro logic
By tommcd64 in forum AudioReplies: 1Last Post: 31st Oct 2008, 19:23 -
A Few Questions About Dolby Pro Logic
By seven_deuce offsuit in forum AudioReplies: 17Last Post: 29th Apr 2008, 15:08
