I am currently using xvid 4psp. In every episode of the tv show I am trying to convert the voices and the audio are clearly out of sync I have tried to correct this to no avail. At this point I am just looking for a software that will compress the video and then convert it to MP4/PSP/Format.
I am just looking for advice on which program to use?
I have tried the sly Soft and Magic DVD Ripper. Ihave also looked up other way to dothis using freeware but none of them compress the video to make it smallerlike xvid does. XVID's Help forum was useless.
Please dont tell me about PSP 9 because it does the same thing. I am willing to use a pay for product. In fact i would rather use something that I paid for instead of the free ware since I have had nothing but failure from these products
But if any one can reccomend a freeware product that can do this that is not to hard to use please let me know.
Thank You
What format are these?In every episode of the tv show I am trying to convert the voices and the audio are clearly out of sync
Corel Dvd Copy 6 works well and has a psp setting. I use it to convert dvds to my zune. I have anydvdhd and I can rip and convert from dvd to zune wmv without ripping to the harddrive first. Anydvdhd decrpyts the disc while you are converting it to a diffferent format. You can use the standard def anydvd for regular dvds, the hd is for hddvds and bluray.Originally Posted by jmgrande
I have had great quality and little to know issues on synching.Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
to answer the question what format my movies are in. Some of my movies are downloaded copies. Some of them are DVDs. All of the movie I am trying to convert are in standard DVD format.
Are your conversions somehow using VBR audio? VBR audio is often to blame for sync issues.
DVD to PSP
By rkersh409 in forum DVD RippingReplies: 1Last Post: 10th Jan 2009, 09:08 -
DVD disc -> PSP Console
By coody in forum DVD RippingReplies: 1Last Post: 23rd Dec 2008, 16:56 -
My XviD4PSP PSP video conversions are not supported on PSP
By godfist314 in forum Portable VideoReplies: 3Last Post: 18th Aug 2008, 10:59 -
Downgrade your PSP to version 1.5 using your PSP battery
By chrise in forum Newbie / General discussionsReplies: 1Last Post: 20th Dec 2007, 08:27 -
Nero 8 Recode to PSP - No Title on PSP?
By sonicm in forum Video ConversionReplies: 1Last Post: 6th Dec 2007, 14:13
