I'm using Virtualdub 1.9.6 and am having a problem loading wmv files and I have the wmv plugins and in the VFW configuration I have wmv1/7, wmv 2/8, wmv 3/9 and vc-1 all marked as wmv9. I still get "asf files not supported". Any ideas as to what to do?
thanks
Results 1 to 11 of 11
Run one of the videos in question through MediaInfo, tree view, and post the information here.
WMV/WMA are just the latest version of ASF, really. Are you sure all of your VirtualDub program folder and plugins are up-to-date?If cameras add ten pounds, why would people want to eat them? -
I'm pretty sure the plugins are up to date. I downloaded them from the this site under the guides for Virtual Dub plugins.
@El Heggunte, I have all of my plugins in the plugins folder, I just can't remember if the folder is called "plugins" or "plugins32". I'm at work now, so I'm not sure. -
"plugins" is for the .vdf files.
"plugins32" is for the .vdplugin ones. -
All you need is a plugins folder unless you are running a 64bit OS then you would have a plugins32 and a plugins64 folder.Originally Posted by El Heggunte
uglijimus, we need to know more about the file you cannot open. Post a mediainfo text or screenshot.
As long as you have the WMV Plugin in the Plugins folder and ffdshow vfw configuration for WMV1,WMV2 and WMV3 set to WMV9 and VC-1 set to libavcodec then you should be able to open any windows media file. You also need the DivX 3.11 codec since Virtualdub sees the audio of a lot of windows media files as DivX 3.11 audio.
I assume you have the WMV9 codecs on your machine.
Do you have problems opening any other WMV files in Virtualdub or just asf files or only certain asf files? -
You're right. Thanks for the correction.Originally Posted by DarrellS
Me too was misled/misinformed by the readme.txt written by Mr. FCChandler.
If it works in version 1.8.8 then it should work in a newer version of Virtualdub.
I'd install Virtualdub 1.9.3 and either reinstall all the plugins or copy everything from the plugins folder of a working version. Every time I upgrade, I just copy the contents of the plugins folder to the newer plugins folder.
You may need to contact Phaeron in the Virtualdub forum and find out what to do with a 64bit version. I just installed the 32bit version on my friends computer with 64bit XP and installed 32bit codecs...
Installing the 32bit codecs on Windows 64
Extract all the files to a folder
Open up a command prompt (start->run: cmd)
Change directories to sysWOW64 ("cd C:\windows\syswow64")
Type the following (replace example_path with the actual path to the extracted files), then hit enter:
rundll32.exe setupapi.dll,InstallHinfSection DefaultInstall 0 c:\example_path\AC3ACM.inf
This method can be used for installing all 32bit codecs that install via a .inf file. -
I just realized mpeg2 files do not work either.
I think I'm going to stick with the 1.8.8 32 bit version (since it gives me less headaches) until the 64bit becomes more compatible. Thanks for all of your replies. I hope others will find this thread helpful as well.
Virtualdub thing contains a virus
By KneeRow in forum Video ConversionReplies: 35Last Post: 24th Oct 2025, 16:47 -
such a thing as protected mkv?
By maca in forum Video ConversionReplies: 3Last Post: 24th Dec 2011, 19:10 -
Any such thing as a raw capture?
By VHSMadness in forum Capturing and VCRReplies: 12Last Post: 24th May 2011, 08:43 -
Was wondering if such a thing exists....WAN (Wireless USB connector)
By SE14man in forum Newbie / General discussionsReplies: 4Last Post: 3rd Oct 2010, 04:53 -
Why is there no such thing as 60FPS above 320x240?
By Syclone0044 in forum Newbie / General discussionsReplies: 29Last Post: 28th Sep 2009, 15:22
