I dont know where to ask this, but if anyone here happens to use 3DS MAX I have an odd question that you may be able to help me with.
I am doing a region render as I simply wish to test materials on small portions of my overall image, however I accidently dragged the region box off screen (out of view) and now I cannot get it back!
It must be something simple or a killer bug but in this file which I have done a lot of work and tweaked my render settings, I cannot for the life of me find the region box!
Can anyone shed any light? I will try to find some dedicated 3DS MAX forums but have never posted in any so thought I would try my luck here first.
Thanks if you can help.
Would be much appreciated, to recreate the problem, simply go to render a region render and when you get the box, drag it off screen and then see if you can get it back!
It doesnt ruin things globally, just for that saved file.
Thanks again. -
3heck window is active and has focus or close to r3einstall
actually is downwarrows and you have to focus that window;also check the settings in render floatwindow to use the "output render window",try
3DS Max vs Maya vs Cinema 4D
By surferadi96 in forum EditingReplies: 7Last Post: 12th Feb 2012, 17:13 -
Help with importing tracking data from Boujou to 3DS Max.
By surferadi96 in forum EditingReplies: 3Last Post: 11th Feb 2012, 10:30 -
Help with 3DS video format
By Mopeto in forum Video ConversionReplies: 7Last Post: 8th Dec 2011, 10:01 -
Nintendo 3ds slashes price to 169.99 usd
By yoda313 in forum Off topicReplies: 0Last Post: 31st Jul 2011, 09:35 -
Nintendo 3DS 3D-AVI?
By Blrock in forum Newbie / General discussionsReplies: 7Last Post: 30th Mar 2011, 08:48
