I have tons of my Granchildren's old vhs tapes. I want to convert them into DVD. I have the program and the wire put when i plug it into my computer it says that it is an unown device. The type of VCR is a Panasonic PV-7456-K. Can anyone help?
Results 1 to 14 of 14
I'm not sure what you mean by "the program" and "the wire." A computer will not normally accept a video input (from, e.g., a VCR). An extra widget, called a video capture card (or box) is needed. If you have such a widget, then it needs to be installed properly prior to use. To do that, follow the instructions that came with the capture device.
The easiest method, though, is to skip the computer altogether and use a dedicated DVD recorder. This is a separate box, and it behaves just like a VCR, except that it records directly to DVD instead of to tape. There's no software to install, no tricky interactions with the computer. Just plug the audio and video from the VCR into the corresponding inputs on the DVD recorder. Basic DVD recorders can be purchased for less than the cost of many capture cards. -
Save yourself a lot of time and grief ...... follow tomlee59's advice... dump he computer and get a DVD recorder
Just make sure you buy quality blank DVD disks... -
Originally Posted by bendixG15
"Quality blank DVD disks[sic]" in the USA means either Taiyo Yuden (you'll have to order them online) or Verbatim (available at major retailers) and nothing else. -
What I meant by Wire is the adapter that i plug into my computer that also goes into my vcr.
The Program is GoldenVideos. -
You need to install the software that came with it or go to GoldenVideos website, you will need drivers for the device and capturing software.
BTW: I also recommend a DVD recorder. -
"Tons" of tapes? And you want to use some dinky USB capture wire? You're on the wrong horse, facing backwards, without a saddle. Forget using your computer setup for this: the "cheap capture wire/PC" route only works if you really know what you're doing and you only have a handful of tapes. Get a damn DVD recorder like any sane person and do it that way. The PC is for super-genius types who know how to keep the cranky software working properly and want to waste years of their lives trying to make the video "perfect" (a thankless task if there ever was one). The DVD recorder just works, exactly like copying from VCR to VCR except you're making DVDs.
DO NOT buy a "combo" VHS/DVD recorder- these never work right. If you're on a tight budget, pick up the cheapest "tunerless" DVD recorder you can find, shop online if your local stores only carry combos. If you have more than 50 tapes to do, and don't mind making a temporary "investment" that you'll get back when you're finished, the best DVD recorder sold in Canada right now is the Sony RDR-HX780, selling in Future Shop for $299-399 (depending on weekend sales promotions). This model has a built-in hard drive as well as a DVD burner, making it ideal for transferring old tapes: you copy the tapes to the hard drive first, cut out any junk you don't want (commercials, etc), and then burn a final DVD at high speed. The hard drive also lets you make multiple copies of the same DVD in case any other family members want one. All without tying up your computer and making yourself crazy. When you finish all the tapes, you can resell the Sony on eBay to some desperate American who's jonesing for one (they aren't sold in USA stores). You should be able to get close to what you paid for it, DVD/HDD recorders are a hot commodity on USA eBay.
There are only two blank DVD brands worth buying anymore: Taiyo Yuden (TY) and Verbatim. Verbatim on sale for $25 is good, at the "regular" non-sale price of $59 they're out of their minds. The simplest way to easy burning and durability is to order the TY Premium 8x DVD-R online from media vendors like rima.com or supermediastore.com. TY is almost always on sale for $25/100 delivered (perhaps a little more for shipping to Canada). -
where in canada are you?
PAL/NTSC problem solver.
USED TO BE A UK Equipment owner., NOW FINISHED WITH VHS CONVERSIONS-THANKS -
If you do get a DVD Recorder, don't forget to check what type of discs you can record on. For me, DVD+DL (Dual Layer) recording was essential. I also only use DVD+R, not DVD-R, as they are more compatible with my older DVD players. A dual layer disc will give you more recording time than a standard disc. I have two recorders and like both. I have a Lite-On and a Panasonic. They are both very easy to use/program. Good luck.
It Started In Texas -
Originally Posted by jman98
Originally Posted by tomlee59
Get a good VCR, too. Whatever you have now probably is not good.
How many tapes is "tons" exactly? Maybe some nice person on here would be willing to do it for you on the cheap!
VCR/VHS playback - lines on picture...vcr alignment problem or no?
By daysaf00 in forum Capturing and VCRReplies: 1Last Post: 23rd Jan 2012, 00:54 -
Which VCR and DVD Recorders?
By Canes in forum DVD & Blu-ray RecordersReplies: 26Last Post: 11th May 2010, 20:48 -
help to unlock my dvd/vcr
By wawabig in forum Software PlayingReplies: 2Last Post: 11th Feb 2008, 10:37 -
GoVideo DVD/VCR
By candela in forum DVD & Blu-ray RecordersReplies: 2Last Post: 10th Dec 2007, 09:05 -
Best VCR OR VCR/DVD COMBO for restoration
By demonwarrior in forum Newbie / General discussionsReplies: 7Last Post: 24th Aug 2007, 02:02
