I have bought a new power supply : Chieftec CFT-650-14CS http://www.chieftec.com/super-power.html
and I am trying to connect it to my motherboard and all the other stuff but when I try to start the pc then I get all the fans working but I think it's something wrong with the dvd writter because it makes a strange sound.
also I have an 8 pins cable which I don't know where to connect.
My motherboard is ASUS M4A78-EM
Any help please, I really need to fix this fast...
the 8 pin cpu cable isn't used on your m.b. only the 24 pin and a 4 pin cpu.
try getting to the bios with just the m.b. and video card connected to power. -
Then remove it (disconnect the power and data cables) and try booting from the hard drive.Originally Posted by alintatoc
I managed to make it work but I had to split the 8 pin into 4 and 4 and I connected one to the motherboard also.
Actually first I trying with the 4 pin, but it didn't work, but then when I split the 8 pin into 2, then it suddenly worked.Originally Posted by minidv2dvd
What is this device? (rf in-out with power supply?)
By cynikalhedonist in forum Capturing and VCRReplies: 11Last Post: 23rd Mar 2011, 12:11 -
Power supply numbers
By kenmo in forum ComputerReplies: 11Last Post: 14th Jan 2011, 10:18 -
Need to choose a power supply
By neworldman in forum ComputerReplies: 4Last Post: 4th Aug 2010, 08:26 -
Bad Power Supply
By AuroEdge in forum ComputerReplies: 4Last Post: 14th Jan 2010, 00:41 -
Power Supply Question
By jjis in forum ComputerReplies: 10Last Post: 6th Nov 2009, 08:35
