I am new to this and will learn. To anyone with suggestions I really appreciate your assistance.
I did search on google for this issue and on this forum but found no results with any answers, not much results found at all.
I am transfering my home movies off a Sony miniDV cam and in type 2. Have not done any compression or editing on any of them. My next plan after transfering is to split them up by dates.
I used WinDV to transfer the files on a Vista Ultimate x64.
All of my files are atleast several gb in size because most of the tapes are atleast 60 minutes long.
They also play just fine in VLC and I am able to open them in VirtualDub.
But I am concerned about the messages I get when checking with AVIcodec and GSpot and want to find out what they mean before I start doing anything with the raw files.
Now to the two specific questions I have
[AVIcodec question]
When checking some of them in AVIcodec it will give popup message:
file.avi is incomplete (too small)
What does that message mean, is there something wrong with the file?
[GSpot question]
When checking some of my files in GSpot in the Container section there will be a Note.
Example: Note: 11.4 GB uneeded bytes at end of file
What does that mean?
Anyone know where I can find out the answers, such as another forum if nobody knows it here?
Still haven't found an answer, will try another forum if anyone has any suggestions?
I don't know what it means off-hand. But I'd wonder if it's even important.
Programmers and videographers don't always speak the same language. Some of the stuff I read in video software doesn't even make sense, be it goofy statements, or just confusing techie/geeky ones. Honestly, I just ignore it unless I detect problems in the video/audio.Want my help? Ask here! (not via PM!)
Thank you for the reply lordsmurf.
Yeah I think i'm going to have to ignore it, since it is working fine.
Just don't know enough about any of this to know any better.
I am concerned that maybe the file is too large and could be smaller or that it might be a problem when I want to compress the file.
Which is the next step to learn, probably convert to xvid. -
I do have a dual boot with WinXp too, but its also x64, but I could try within it to see if I get the same results.
Newb questions - re. HD&MiniDV Camcorders & Capture
By The Big Cheese in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 1st Jan 2009, 18:21 -
Gspot Specs Related Questions.
By scott274 in forum Newbie / General discussionsReplies: 9Last Post: 28th Jul 2008, 23:09 -
his ipod questions?
By joyy in forum Newbie / General discussionsReplies: 1Last Post: 23rd Jan 2008, 03:15 -
Figuring out why this AVI file crashes MPC & AVIcodec
By DRP in forum Software PlayingReplies: 14Last Post: 11th Nov 2007, 21:19 -
AVICodec reports wrong frames per sec
By igorek in forum Newbie / General discussionsReplies: 1Last Post: 6th Sep 2007, 20:27
