Does anyone have a simple guide to do this?
Try Any Video Converter Free Version. It has Zune presets. You will probably have to decrypt the DVD first with DVDFab HD Decrypter, then you could use VOB2MPG to extract the main movie to a MPEG, then convert that to Zune format.
There's probably an easier way, but I'm not that familiar with the requirements of the Zune players. But others here may know.
i like xmediarecode for zune conversions. you can select the dvd ifo from the dvd drive and not have to copy to the hard drive. if it's a retail dvd you will need anydvd running to remove the protection in the background.
you can also choose the ifo from the video_ts folder after ripping to the hard drive if you wish.
you can choose to produce wma, mp4, or h264 files.
fairly fast. h264 dvd conversion from a hard drive video_ts is about 20 minutes.
want to convert .ts files to mp4 for play on zune..
By heysemo in forum Newbie / General discussionsReplies: 8Last Post: 15th Jan 2015, 03:36 -
Which Software To Use For Zune 80GB Player
By V Bot in forum Portable VideoReplies: 6Last Post: 15th Apr 2014, 14:42 -
How Can I Convert Real Player Video Files To Make Them DVD Player Compatabl
By Lennoxtown in forum Video ConversionReplies: 8Last Post: 17th Oct 2007, 07:05 -
Convert to Zune compitable Qucktime using tmpgenc 4
By frogman54 in forum Video ConversionReplies: 1Last Post: 14th Jun 2007, 15:21
