I use Donald Graft's logo filter to put a bitmap logo on my vids , I want to make the background of the logo seems transparent. I do it easily by the internal VDubmod logo filter , but i want to use Donald Graft's logo filter because it gives me more options ...... How to set the color channel values to produce a transparent color?
the logo is like that:
I believe a transparent logo must be a .tiff or something other than a bitmap or jpeg.
His filter uses masks, so on the mask layer, areas that are white transmits the the corresponding area of the logo, areas that are black become transparent and show the video layer.
You would make the mask in photoshop or other image editor (maybe gimp, irfanview etc...), and it has to be 24-bit .bmp , just like the actual logo
You have to name the mask the same name as the logo, with the letter A at the end
e.g.
Here is an example of a mask, but you can make the white/black areas whatever you want to let areas show through
1062009115547pma.bmp -
thank u so much , I could manage it with your instructions.Originally Posted by poisondeathray
You r always the best one who helps me at this forum
thanq 4 response , but by this filter u can use only bitmap logos .... its solved by poisondeathray s constructions.Originally Posted by hech54
avisynth - overlay fadein from transparent
By doma79 in forum EditingReplies: 12Last Post: 6th Dec 2011, 11:38 -
subs look transparent (sub/idx)
By X_Splinter in forum SubtitleReplies: 2Last Post: 22nd Dec 2010, 10:26 -
Transparent logos, aegisub and AviSynth
By shorto in forum EditingReplies: 17Last Post: 20th Feb 2010, 19:35 -
DVD logo with a transparent background
By cobra jet in forum Newbie / General discussionsReplies: 4Last Post: 26th Jun 2008, 15:31 -
Subtitle background is not transparent *solved*
By Meriks in forum SubtitleReplies: 3Last Post: 9th Feb 2008, 15:47
