Hi! I author lots of DVDs for my costumers, when the costumer authorizes I
keep a copy in case the costumer wants more copies in the future, now the problem
is cluttering.. I have lots of spindles everywhere, and I have backup drives that go bad.
I was looking at BD recording as an alternative, in a 25GB BD-R I can fit a lot of DVD ISOS right?
Can I use a program like NERO Burning Rom to burn the files?
and finally do you know of a good BD-R writer? thanks a lot guys!
-Peace!
Results 1 to 10 of 10
Sure you can burn DVD iso's to a data disc formatted BD disc , just put the iso's in a folderOriginally Posted by faramith
I recommend the Pioneer BDR-203, i have had it for 2-3 months and couldn't be happier w/ it
LG read commercial BD-ROM (commercial release Blu Ray movies) discs slower than their BD-R rating because they treat BDMV files differently (4.8x vs 8x)
http://forum.slysoft.com/showthread.php?t=32810&page=2
ocgw
peacei7 2700K @ 4.4Ghz 16GB DDR3 1600 Samsung Pro 840 128GB Seagate 2TB HDD EVGA GTX 650
https://forum.videohelp.com/topic368691.html -
If you burn DVD folders to the "root" of a drive it works the same as if you made a iso image and burned it to the discOriginally Posted by faramith
If you take a iso image created w/ imgburn and put it in a folder and then copy the folder to the disc it is a data disc
You can put multiple DVD iso's on a blu ray disc, just put them in a folder or folders like a suggested for a multiple dvd blu ray data disc
Look for any good name brand BD Burner other than LG for the reason I already mentioned, besides newgg, zipZoomFly, and Tiger Direct are good reputable online retailers w/ competitive pricing
or try a high rated Amazon retailer
ps. i also use Verbatim disc almost exclusively for DVD, CD, and Blu Ray
ocgw
Why not use hard drives for backup of ISOs?
Less expensive in terms of cost/GB , don't need a BD-R burner, probably more reliable, less clutter
With the cost savings you could have multiple drives with multiple copies for extra security -
I don't use ISO's that often, but I assume if you add them to a data disc, ('Write files/folders to disc' in EZ-Mode Picker) ImgBurn will burn them as data and ignore the ISO container designation. Don't use 'Write image file to disc' or it will just let you use one. If it has a problem, it will usually tell you and suggest a solution.
Thanks, Ive been doing backups in HDD too but it fills up fast and also it can crash... with BD-R I can burn as many as id like too
Thanks for your replies, Ill check in other stores other than newegg since its already out of stock there.
Peace -
I think the business model is flawed. Most customers can copy their own discs. I'll teach mine how to copy their own discs. As you're finding out, storing the discs is a hassle, and your ROI is negative long-term.
Ill start to store them for 1 year(optional), that's part of the contract they'll sign from now on, still I have costumers that order a few copies over 1 year that's an extra income tho.
Backing up my Blu Ray Discs
By John75 in forum Newbie / General discussionsReplies: 5Last Post: 6th Jan 2011, 20:27 -
Backing up blu-ray shortcut
By alucard2050 in forum Blu-ray RippingReplies: 4Last Post: 1st Dec 2009, 10:10 -
burning and playing blu ray/hd content onto discs onto dual layer discs
By julie_152 in forum Authoring (Blu-ray)Replies: 18Last Post: 21st Sep 2009, 13:36 -
Backing Up Death Race Blu-Ray
By mr.adventure in forum Blu-ray RippingReplies: 26Last Post: 14th Jan 2009, 10:18 -
Can I rip Blu Ray Discs with LG Super Multi Blu-ray Disc and HD DVD-ROM Dri
By donpato in forum Blu-ray RippingReplies: 5Last Post: 5th May 2008, 16:05
