  1. Member miilk's Avatar
    Oct 2009
    ok so. i recorded my first video ever last night. it's only like a minute long(avi format). i used the webcam in my laptop.
    it's says it's 395 mb, which seems really big to me. i dont really know anything about video.
    so i guess my questions are..
    1- is that really big?
    2- if so, how do i make it smaller?
    3- can i record a video as wmv, instead of avi?
    thanks!!
  2. Member edDV's Avatar
    Mar 2004
    Northern California, USA
    1. No. Depends on the webcam resolution, frame rate and codec used.
    2. Consider a different resolution, frame rate or compression codec.
    3. Yes. Try to capture with Windows Movie Maker or Windows Media Encoder.
    http://www.kiva.org/about
  3. Member miilk's Avatar
    Oct 2009
    what is a codec?
    ..and thank you
  4. Member edDV's Avatar
    Mar 2004
    Codec means encoder-decoder. WMV is a codec supported by Windows. Try that first.
    http://en.wikipedia.org/wiki/Webcam
    http://en.wikipedia.org/wiki/Videoconferencing
    http://en.wikipedia.org/wiki/Codec
  5. Member bendixG15's Avatar
    Aug 2004
    Originally Posted by miilk
    what is a codec?
    ..and thank you
    A codec is ----------------->>> https://www.videohelp.com/glossary?C#Codec
    I am sure you will have many other basic questions.
    You will find much valuable info by checking out the stuff on the LEFT side of this screen.
    That's where the codec info comes from.
    Happy reading
    Edit .........edDV beat me to it
  6. Member miilk's Avatar
    Oct 2009
    awesome!
    just that stuff explains a lot that i was confused about.
    thank you both!!
