Hi all , sorry but am a bit new to all this, i have this file and need to convert so i can play through my ps3 so can anyone help with this as i have tried tsmuxer but it wont recognise it.
cheers.
Results 1 to 10 of 10
How did you get this file? Is it from a mkv? Then instead try use the mkv and make avchd using multiAVCHD.
Or use PS3 Media Server to stream to your PS3. -
it is from a MKV i tried the multiAVCHD but like every thing else ive tried it doesnt work, MKVExtract worked as far as changing the 2 audio files but that program doesnt allow you to change it to a m2ts or avchd.
thanks. -
thanks, here it is just cant seem to find any program to change this into a file i can use on my PS3.
Complete name : \Дежавю\New Folder\Deja.Vu-2.mkv.mkv
Format : Matroska
File size : 6.58 GiB
Duration : 2h 6mn
Overall bit rate : 7 455 Kbps
Movie name : Deja Vu (2006)
Encoded date : UTC 2009-10-04 11:10:35
Writing application : mkvmerge v2.9.8 ('C'est le bon') built on Aug 13 2009 12:49:06
Writing library : libebml v0.7.7 + libmatroska v0.8.1
Format : AVC
Format profile : High@L5.1
Format settings, CABAC : Yes
Format settings, ReFrames : 8 frames
Muxing mode : Container profile=Unknown@5.1
Codec ID : V_MPEG4/ISO/AVC
Duration : 2h 6mn
Bit rate : 6 667 Kbps
Nominal bit rate : 6 853 Kbps
Width : 1 280 pixels
Height : 536 pixels
Display aspect ratio : 2.35:1
Frame rate : 23.976 fps
Resolution : 24 bits
Colorimetry : 4:2:0
Scan type : Progressive
Bits/(Pixel*Frame) : 0.405
Stream size : 5.88 GiB (89%)
Writing library : x264 core 54
Encoding settings : cabac=1 / ref=5 / deblock=1:-1:-1 / analyse=0x3:0x133 / me=umh / subme=6 / brdo=1 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=2 / deadzone=21,11 / chroma_qp_offset=0 / threads=3 / nr=0 / decimate=1 / mbaff=0 / bframes=4 / b_pyramid=1 / b_adapt=1 / b_bias=0 / direct=1 / wpredb=1 / bime=1 / keyint=250 / keyint_min=25 / scenecut=40(pre) / rc=2pass / bitrate=6853 / ratetol=1.0 / rceq='blurCplx^(1-qComp)' / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / pb_ratio=1.30 / aq=1:0.5:16.0
Language : English
Format : AC-3
Format/Info : Audio Coding 3
Codec ID : A_AC3
Duration : 2h 6mn
Bit rate mode : Constant
Bit rate : 640 Kbps
Channel(s) : 6 channels
Channel positions : Front: L C R, Surround: L R, LFE
Sampling rate : 48.0 KHz
Stream size : 579 MiB (9%)
Title : Deja Vu
Language : English
Thanks again. -
You can try to name your path+file to standard ASCII characters.
What error does multiAVCHD report when you add this file?Laugh and the world will laugh with you. Cry and you will be alone -
To use transcoding you need to have haali splitter and avisynth (and may be ffdshow)... You can try to enable the option in settings [x] Use FFms2 instead of Directshow and give it another try. Have in mind that if you enable this option there will be a slight delay (of 2-5 mins) before transcoding starts (of before "title properties" window appear), so just wait for it.
thanks, i have all those installed so ill change it and see how i go.
cheers. -
thanks multiAVCHD but that didnt work either.
comes up with fail all the time yet i know the program works with others i have.
in the output folder suffix should i leave this blank.
Rip to ISO or MKV or M2TS for use with Seagate Freeagent Theater+ HD?
By FuzzyReets in forum Blu-ray RippingReplies: 0Last Post: 15th Dec 2010, 20:26 -
iso to m2ts
By Benjy in forum Blu-ray RippingReplies: 2Last Post: 5th Sep 2010, 13:00 -
Extracting xvid (V_MPEG4/ISO/ASP) from MKV
By 20000RPM in forum Video ConversionReplies: 2Last Post: 7th Feb 2010, 21:49 -
MKV avc to m2ts via tsMuxer;1080p muxing problem for ps3. Please
By rafoolik in forum Blu-ray RippingReplies: 5Last Post: 11th Aug 2009, 18:55 -
Converted from m2ts into Sony AVC MP4 and got lines on objects
By dilfatx in forum Video ConversionReplies: 4Last Post: 1st Dec 2008, 12:00
