I connected my pc (optical out) to my amp optical in but still I can get no sound in the amp speakers, why is that?
Any ideas?
Results 1 to 10 of 10
Turn the power on?
Really can't help with so little info given -
Sometimes you have to configure the audio via Control Panel or a manufacturer's applet to use analog vs. optical (some only permit one or the other).
You prolly gotta' enable spdif output from your sound card, and if using pci sound card definitely disable OB audio in BIOSOriginally Posted by alintatoc
ocgw
peacei7 2700K @ 4.4Ghz 16GB DDR3 1600 Samsung Pro 840 128GB Seagate 2TB HDD EVGA GTX 650
https://forum.videohelp.com/topic368691.html -
What is pci sound card?Originally Posted by ocgw
I tried to search for something in the control panel/sounds but I couldn't find anything to enable the optical cable... -
Unless you installed a pci sound card you you have onboard sound and the optical input(spdif)is connected right to the motherboard,just do what JohnnyMalaria said.
I'm so happy for you. Care to make the discussion useful for future users by posting exactly what you did?
In case anybody has missed it, this will be about the eighth time this particular user has posted a fairly clueless question with little extra info, and has yet to post a single instance of just what step has solved the problem reported.
I'm not sure if this qualifies as troll behaviour, but I am questioning whether anyone can truly be this stupid.
Waste of time on a person who will not even take the time to describe the working solution. Bye-bye, off my list. -
And now you know why I posted:Originally Posted by Nelson37
Not everybody is as smart as you are...unfortunately
Connection help please
By Malissa in forum DVD & Blu-ray PlayersReplies: 1Last Post: 4th Dec 2011, 09:10 -
No sound on HDMI connection from PC to TV
By David747 in forum DVB / IPTVReplies: 5Last Post: 23rd Aug 2009, 00:27 -
PC to TV Connection help
By mohit in forum Media Center PC / MediaCentersReplies: 5Last Post: 22nd Sep 2008, 15:15 -
By mohit in forum Video Streaming DownloadingReplies: 1Last Post: 21st Sep 2008, 10:03 -
firewire connection without sound
By m baqar in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 25th Apr 2008, 08:10
