Results 1 to 10 of 10
Read my blog here.
Thank you very much for the link... installing and downloading now...WindowsXPMode.exe file is huge and @ 980K sec is still going to take a few minutes...
I'm also trying AutoGK... seems ok, so far... Converting a movie now. Does that do Divx? or just plain AVI? if you would choose between the two which one is better? -
Divx (the container, as opposed tot he codec) is just an extension of the AVI container to allow for the Divx specific features such as chapters and menus. Of course to use these fully tou also need a Divx Ultra capable player.
if you are just doing standard encodes the AutoGK can use the Divx codec to compress videos into the AVI container.Read my blog here.
It does either XviD or DivX for AVI. The XviD is included. You're on you own for getting and installing the DivX codec.
Which is better? Six of one and half a dozen of the other if you ask me. But I use XviD. -
It would seem I fixed it.... During the crashing of the application, I quickly went into task manager and right clicked all the processes associated with the program and told it to run in compatibility mode, as Windows XP SP3. and everything worked again...
Happy I was persistent.
joe
Can't Mux Back To VOB Using ANY Program avaliable PLEASE HELP!!!
By GizzmanSL2 in forum Authoring (DVD)Replies: 6Last Post: 8th Nov 2010, 08:20 -
Program that allows direct VOB burning AND menus
By 6079 in forum Authoring (DVD)Replies: 8Last Post: 22nd Jul 2009, 06:15 -
Which program to use for converting VOB to H.264 MPEG4
By user123456 in forum DVD RippingReplies: 1Last Post: 24th May 2009, 03:20 -
A sad day for Lions fans???
By yoda313 in forum Off topicReplies: 18Last Post: 30th Apr 2009, 08:00 -
Conversion Program
By geoffggreer in forum Newbie / General discussionsReplies: 2Last Post: 19th Aug 2007, 07:15
