Results 1 to 15 of 15
  1. Hello many tv tuner cards allow you to watch OTA HD on your computer, but when you record them, it encodes it in mpeg 2 standard def. Is there a tv tuner card that can record HD?
  2. Member Soopafresh's Avatar
    Jan 2004
    "Quality is cool, but don't forget... Content is King!"
  3. Member edDV's Avatar
    Mar 2004
    Northern California, USA
    Most if not all don't encode. They simply tune the ATSC stream and extract the subchannel stream you have tuned and stream that to a file. The resulting MPeg2 file will be HD and audio will be AC3 if that's how it was broadcast.
    Do you have more specific examples?
    BTW: A killer product would be one that did convert an HD stream to wide DVD aspect all in hardware. People spend hours trying to do that in software. If you know of a tuner that will make the conversion in hardware I am all ears.
    http://www.kiva.org/about
  4. Member netmask56's Avatar
    Sep 2005
    Sydney, Australia
    Certainly available in PAL land. The Dvico cards produce a MPEG TS file containing audio video and subtitles and the aspect ratio is always 16:9. These streams can be demuxed with ProjectX. Dvico does make an US model
    2.35:1 is letterboxed within the 16:9 frame and 4:3 material is pillaboxed. Same for the Beyonwiz and Topfield PVR's in fact all tuners available in Australia. I think it all depends on the local transmission standards
  5. So any tuner with record the HD stream? I'm looking at the Happaguage dual tuner cards, will they record the HDTV signal as is?
  6. Member 1st class
    Aug 2004
    Charlotte
    [quote=edDV][quote="peggypwr1"
    Most if not all don't encode. [/quote]
    Yes and no. I don't know of any cards that perform hardware encoding, but two tuners I have, a Pinnacle USB and Dvico PCI card both came with trialware that performed on-the-fly software encoding to SD MPEG2, Divx and some other codecs. I don't think the average user with a dual core processor would notice the difference between hardware encoding and on-the-fly software encoding.
  7. But, thay both record the HDTV stream on your HDD? THis is what I am looking for. I just want the HDTV 1080i ppicture on my HDD, then I can convert it later.
  8. Member 1st class
    Aug 2004
    Charlotte
    Every OTA tuner card on the market today will record HD on your hard drive.
  9. Member netmask56's Avatar
    Sep 2005
    Sydney, Australia
  10. Member edDV's Avatar
    Mar 2004
    [quote=festmaster][quote=edDV]
    On-the fly or real time software decode/resize/encode will take many shortcuts to keep up. In other words a much lower quality result than doing it with the normal non-realtime methods.
    They probably start with the poor man's deinterlace by tossing a field resulting in half the motion increments or jumbled telecine.
  11. Member edDV's Avatar
    Mar 2004
    That is what you should be getting. Since no processing is going on, CPU load is near zero if you don't monitor the capture. Monitoring an HD stream will take a heavy hit on CPU and/or GPU resources.
  12. Member edDV's Avatar
    Mar 2004
    That is exactly the way it was broadcast. The tuner card is just passing the stream to a file.
  13. Member Soopafresh's Avatar
    Jan 2004
    That's a good card as well. Both the Fusion and the MyHD cards are the most popular HDTV tuner cards out there. Avoid ATI. Good company, bad HD tuners.
    Mar 2009
    peggypwr1,
    I think your computer is a little anemic for HD capture of anything. Unless of course your computer details are wrong. Please check the software and hardware requirements before you invest $200.00 in a hdtv card.
    Reelman472
    Jul 2007
    Why are ATI HD tuners bad ? Uh-oh, I just bought an ATI 650 external USB tuner and installed it on my pretty
    old computer..... seems to work fairly well with OTA ATSC signals..... the software sucks though, uninstallling the
    Catalyst Media Center is very difficult, as is the ATI drivers..... I'd like to try Beyond TV, but installation crashed
    the computer. The ATI tuner card and software is from 2007
