What would be the best program to create an easy to use DVD Menu template that works with both Premiere and Final Cut exported MPEG2 files?
Basically, I'd like to be able to create my own DVD Template - use my own background, logos, button designs, etc...
I then need chapter select pages that interact with the imported MPEG2 files - create buttons for the number of chapters detected (and give each button a chapter name that would have been imported from the MPEG2 file information).
Right now I'm using Adobe Encore DVD as well as DVD Studio Pro. I have templates already created in Photoshop, which are then imported into the DVD Authoring Software, chapter titles are added manually, and then each button is linked to its respective chapter.
A way to automate this process would be wonderful - we do many edits with long shows here, and anything to speed up this process would save alot of time.
Is there a program that can do this? If so, can it also create Blu-Ray menus in the same fashion?
Any help would be greatly appreciated.
Thanks,
Billy
Closed Thread
One similar topic is enough. https://forum.videohelp.com/topic373968.html .
Menu difference b/w Blu-ray on DVD
By cheerful in forum Newbie / General discussionsReplies: 0Last Post: 2nd Dec 2011, 20:56 -
Blu-ray with menu does not play on DVD+R, but does on BDRE
By sosotiit in forum Authoring (Blu-ray)Replies: 6Last Post: 8th Feb 2011, 04:13 -
Multiavchd..Need Help..MKV-BLU RAY-- Freezing on Blu Ray Menu!!
By Thuglas in forum Authoring (Blu-ray)Replies: 1Last Post: 14th Sep 2010, 22:58 -
Ripping Blu-ray for PS3 and possibly XBOX360 streaming
By tstein in forum Blu-ray RippingReplies: 1Last Post: 25th Feb 2010, 18:38 -
DVD / Blu-Ray Menu Creation
By motown01 in forum Authoring (DVD)Replies: 3Last Post: 7th Oct 2009, 14:15
