    Jul 2009
    My computer (with Windows XP) has started to run slower. I have ccleaner, super antispyware, and malware bytes, as well as spybot. I ran registry optimizer and it said it found almost 300 issues. But to fix them you have to buy a subscription. Is this just a money maker or is there something I can download (preferably free) that I can use to fix these.
  2. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    Originally Posted by BLSAMPLES
    I have ccleaner
    CCleaner's registry cleaner perhaps?
    Jun 2009
    I love my CCleaner others i have tryed have removed the wrong stuff not good pc chashed so be very very careful . . . also Crap cleaner is great and very safe to use and love the sound it makes . . . mostly trial and error find and use 2 then compare the listed issues just google freeware and look for reg clearners in the fist 4/5 sites have fun . .
    Feb 2004
    Australia
    Advanced system care 3 is free for home users and it makes backups before anything is done.
    Eusing Free Registry Defrag... personal favorite.
    However, as time moves forward the following factors take place which reduce performance.
    1: Hard drive age and work load ... this includes mft and bitmap table fragmentation.
    2: Outdated applications.
    3: Invalid registry entries ... those created by installed software or replaced by other.
  5. Member usta's Avatar
    Jun 2009
    Netherlands
    Registry cleaner alone is not sufficient.
    Next to the Advanced System Care, there are some other total solutions:
    * Glary Utilities (freeware)
    * TuneIT (payware)
    * System Mechanic (payware)
  6. Member blinky88's Avatar
    Mar 2004
    Australia
    Glary Utilities does a good job.
