I want to export a DVD for YouTube. I've tried reading up on the correct dimensions to export (convert) the video, but different sites seem to have conflicting info. I've read that I should export to 720 by 405 which would maintain my 16 x 9 ratio. But I've also read that really NTSC Widescreen DV only has a vertical resolution of 360. Which would put my other dimension at 640. What is the right dimension to export at?
Thanks...
DV is 720x480 or 720x576 pixels. If your DV is interlaced be sure to deinterlace it also.
But don't use 405 pixels, use a size that is dividable by at least 2 or even better by 16. -
So the 640 by 360 is a better choice? I understand that DV is 720 x 480 (NTSC) but that translated into square pixels is not widescreen...
But it's not square pixels, which is why you had better resize to a square pixel resolution. Like the suggested 640x360 or some such with a similar 16:9 ratio. If you want to get the HQ button at YouTube, then something like 854x480 might be preferred. You can send a couple of short experimental uploads to see how YouTube handles them.Originally Posted by bsuska
Aspect ratio for SD Widescreen on YouTube
By matthewjohn23 in forum Video ConversionReplies: 9Last Post: 1st Nov 2010, 19:14 -
HD Widescreen Youtube for Premiere CS4?
By 3DHDAnaglyph in forum Video Streaming DownloadingReplies: 15Last Post: 24th Oct 2010, 13:15 -
Uploading a video to Youtube that will fill the ENTIRE youtube player.
By Clifurd in forum Video ConversionReplies: 16Last Post: 12th Mar 2010, 14:40 -
YouTube and Adobe Premiere Pro 1.5. What size video? I shoot widescreen.
By vid83 in forum Video Streaming DownloadingReplies: 0Last Post: 17th Jun 2008, 00:32 -
Converting a widescreen video for youtube
By theguy1991 in forum Video ConversionReplies: 9Last Post: 11th Jun 2008, 18:19
