How much hard drive space will a capture of a college football game (3 1/2 hours?) take up from VHS if I want it in VHS quality and to put it on DVD?
Only guessing here, but 3.5 hours of football would probably take about 70-75% of your available hard disk space.
What codec are you using? What resolution?
I use the Pegasus MJPEG at the highest setting and it takes
about 30gb for a 3 hour game. -
I don't, and that is the point. As gm3dalee asked, what are you using? I could say that if you are using a DVCII (hardware MPEG1/2 encoder) and you have it set to VCD standards, it would be 10M/min or about 2.1G total. Or, I could assume you are using the DV Bridge (hardware DV encoder) and it would be about 200M/min or about 42G total. You may have neither of these. I just don't know. And I never will with such an open ended question. Providing more details will result in a better answer.Originally Posted by GatorFan
Uh oh, a gator fan lurks. Just 1 bit of advice. Dont try capturing the '01 Sugar Bowl. It will CRASH YOR SYSTEM!!!!! HA HA 'CANES RULE!!!!!!
Seriously, though, yes......we need more info.
Sharp VCR (or similar) S-VHS quality for best capture of my VHS tape?
By ruehl84 in forum Capturing and VCRReplies: 0Last Post: 19th Feb 2012, 15:52 -
VHS Capture Size Massive?
By donkey33 in forum Capturing and VCRReplies: 17Last Post: 24th Feb 2011, 00:40 -
Which $150 or under capture card for VHS/S-VHS -> computer?
By HDClown in forum Capturing and VCRReplies: 25Last Post: 16th Apr 2010, 22:16 -
Size to Capture VHS at for DVD
By MasterOfPuppets in forum Capturing and VCRReplies: 4Last Post: 3rd Mar 2010, 16:15 -
VHS to DV capture: Component video vs. S-VHS
By vega12 in forum Capturing and VCRReplies: 8Last Post: 19th Feb 2009, 19:42
