I think Xvid4psp defaults to single pass constant quantizer encoding. You can use a lower quantizer to get a larger, higher quality file. Or you can switch to 2-pass VBR encoding and specify a bitrate that gives you the size you want. Use a bitrate calculator or use the bitrate from your source file.
Results 91 to 96 of 96
It defaults to Q=3
If you push the configuration button (labelled "1") , then set the quantizer to 2 (labelled "2") , it will give you better quality, but unknown filesize (but bigger than what you have now)
Or you can do what jagabo suggested and change to 2-pass if you need exact size
that's okay there was nothing wrong with file dvd player is going
played file in another player with the same support
thx for ur help -
Thank you poisondeathray for all ur help and the little patience you had left with me- all day I kept trying the dvd player and would get no disk - until last night the last encode I placed dvd in and it had made this loud sound and vibrating
I watched it the other day and it was fine then last night and today can't even play anything - every disk says no disk
time for a new guess 4 years is a life span on these philips
Lossless Conversion from AVI H.264 to MP4 H.264
By kenchen in forum Video ConversionReplies: 3Last Post: 22nd Oct 2010, 15:04 -
.264 Conversion
By thunderclap82 in forum Video ConversionReplies: 4Last Post: 11th Mar 2010, 18:48 -
Looking for H.264 conversion help
By fordprefect138 in forum DVD RippingReplies: 9Last Post: 24th Nov 2009, 06:19 -
H.264 (MOV) to H.264 MPEG TS conversion
By svens in forum Video ConversionReplies: 0Last Post: 19th Feb 2009, 07:47 -
MPEG1 to H.264 conversion
By sarvagya in forum Video ConversionReplies: 5Last Post: 14th Dec 2007, 04:25
