I'd say <$100 Canadian budget (plus another $100 or so for new HDD)
Computer is P90, Win 95, no AGP.
To record from videotape or OTA/satellite TV, to VCD.
This could be a tough one... The cheapest way to go is a basic TV tuner card, but your system won't have enough power to capture with an MJPEG codec or the like, which is pretty much essential. Even if you could, conversion to MPEG after the fact would take forever. Maybe you might have luck with a hardware-based realtime MPEG encoder, but even if it did work you're pushing the budget.
GT,
I dont think it will be worth your time. Since you have a P90, you dont even have MMX, which you could possibly sub for a video card. I can almost guarantee the powerful software you need will crash your system or just freeze it.
If you are serious about capturing and burning, get a new system or a newer system. If your budget does not allow the newest technology, get a refurbished from a reputable name brand (dell/gateway etc). You can get a $500 system that includes a P3/Athlon 800Mhz 64MB AGP CD-R/RW, etc.
Just my humble opinion.
Cheers -
Yep, look at the $399 PCs on the left:
http://www.ditcorp.com/
Just examples; you can build one yourself just as cheap.As Churchill famously predicted when Chamberlain returned from Munich proclaiming peace in his time: "You were given the choice between war and dishonor. You chose dishonor, and you will have war." -
Mirror,
NICE!!!! I may pickup a that new AthlonXP 1.7 machine on their home page. VERY enticing!!!!
low end quadro is 5 times faster than high end gaming card
By deadrats in forum ComputerReplies: 4Last Post: 7th Apr 2011, 15:42 -
Dependability of low end OLD vcr's
By 389poncho in forum Newbie / General discussionsReplies: 13Last Post: 11th Dec 2008, 07:31 -
Vid encodes will only display first frame instead of loop at the end of vid
By SignedupGuest in forum Newbie / General discussionsReplies: 6Last Post: 8th Aug 2008, 22:09 -
If I purchase a low end DVD player just to watch movies....
By leftyloopy in forum DVD & Blu-ray PlayersReplies: 8Last Post: 12th Feb 2008, 14:02 -
Low End Video Card w/ adapter vs. Low End DVD player
By enter8 in forum Media Center PC / MediaCentersReplies: 6Last Post: 20th Aug 2007, 15:45
