I have a 4 year old LG Plasma TV set with one DVI connection, 720P native resolution. Recently I hooked up my
Win XP (older) computer to the TV via the AGP video card, nVidia FX5200 128mb with VGA and DVI output. Seems
I can only get a correct screen using 1024X768, if I bump up the video card resolution to 1920X1080, the display
is way overscanned with the Windows icons borders cut off. Same with playing DVD videos using Power DVD,
full screen mode cuts off 1/3 of the picture. Is there any way to correct this using resolutions higher than 1024X768 ?
I guess you have tried adjust the overscan size, it looks something like
I'd have to see the manual for your LG TV to be sure of this, but offhand I'm kind of skeptical that your TV will support 1920x1080 if it's a 720p TV. You could try the suggestion and if it works, more power to you. If not, then you can't get full 1920x1080 resolution on that TV.
[quote="joecass"]I have a 4 year old LG Plasma TV set with one DVI connection, 720P native resolution. ...quote]
This is not overscan. What your seeing is that your desktop is larger then your display. You can (though I don't know why...) do this to any monitor. 720p (really 768p) is your native resolution.
Even if your TV accepts 1080i/p input, the only thing it can display is 720p. It will downscale this to 720p* just like it will upscale a 480i/p image to 720p. Your cleanest option is to set your desktop to 1024x768 as you have done.
*Actually, it probably takes your 1080 input, downscales it to 720 and then upscales that to 768. Fine for TV or DVD. Not so good for PC or other input requiring 1 to 1 pixel display.Have a good one,
neomaine
NEW! VideoHelp.com F@H team 166011!
http://fah-web.stanford.edu/cgi-bin/main.py?qtype=teampage&teamnum=166011
Folding@Home FAQ and download: http://folding.stanford.edu/ -
Check your TV's manual. I'll bet it instructs you to set your video card to display at your TV's native resolution and frequency for best results. That's 1360 X 768 and 60 Hz for the 3-year old Samsung 720p TV I've looked into using as a monitor.
Unfortunately the video card is about 4 or so years old, I don't have that same screen in the nVidia settings to adjust the
picture. I remember many years ago, connecting this computer to my plasma TV, adjusting the resolution to 1080i on the nVidia video card, it worked perfectly playing a DVD movie. Don't have the TV manual, pretty sure it is 1024x768 @ 60hz.
Maybe I need an updated video card or updated software. The tv accepts 1080i upconvert signals from other sources using
the Component inputs, so theoretically, it should work with VGA or DVI -
If you know the model number for your TV, look to see if the manual is available for download from the manufacturer's website, or if the technical specs for the TV are there. Either should tell you the native resolution and frequency for your TV.
If it turns out you need a setting that isn't available and you don't have the latest driver installed, updating the driver for your video card to the newest version may provide additional settings. NVIDIA seems to be good about continuing support for older video chips.
Overscan issue w/ HDTV dual-monitor set-up
By Dratheus in forum Newbie / General discussionsReplies: 3Last Post: 18th Apr 2009, 19:36 -
Do Samsung HDTV's have an RF antenna connector for receiving off-air HDTV?
By pianopeddler in forum DVB / IPTVReplies: 2Last Post: 6th Aug 2008, 21:43 -
Need al little help getting my new ati hdtv pci card to sense HDTV channels
By MidnightMike in forum ComputerReplies: 8Last Post: 23rd Jul 2008, 02:12 -
Problems with connection with my Panasonic HDTV and Timewaner HDTV box...
By S4one in forum DVB / IPTVReplies: 7Last Post: 2nd Nov 2007, 22:39 -
Enigmavision HDTV - HDTV viewer software for ATSC TV tuner cards.
By gc04 in forum Latest Video NewsReplies: 9Last Post: 7th May 2007, 00:32
