I have an hour MPEG-file that the audio is out of sync of video and damaged somehow. But I have managed to extract the audio to a wav file.
So my question is:
1. How can I extract the video and join the audio again ?
2. How can I fix the sync problem, it is about 2 seconds ?
Regards
How large is the file and hard drives format ?
If the file is playable you might try vlc in transcode mode to same or other format... thou if there are any serious issues during the playback these will also appear as breaks when viewing the new file.
There is also mpeg2cut which can demux mpegs into elementary streams.
Now audio out of sync how ?
If the amount never changes you could load the m2v (video) into avidemux and add the new audio stream followed by setting the audio preload -??? will move audio earlier ... ??? to move it later.. and output as mpeg or other.
Faster method would be via muxman to vob then extract back to mpeg avoiding any form of re-encoding.
Audio that has a time length which dose not match video and contributes to audio drift are simpler to cure ... audacity for this.
Audio length that matches video length yet drifts requires a lot more work to correct and while this can be done using freeware it's a job left best to products such as vegas and alike which can handle the source and live preview as you work to correct the sync issue.
HELP! Damaged/Corrupted MOV file.
By neil wilkes in forum EditingReplies: 3Last Post: 13th Nov 2011, 08:09 -
MOV files damaged (but play fine in VLC) -repair how?
By tigrr in forum Video ConversionReplies: 9Last Post: 4th Feb 2011, 16:34 -
[HELP] Fix File. damaged AVI ?????
By Warfighter in forum Video ConversionReplies: 1Last Post: 19th Sep 2010, 18:10 -
Damaged MPEG-4 File recovery
By bLAcKOuT. in forum Newbie / General discussionsReplies: 4Last Post: 11th May 2009, 15:25 -
Damaged m2t file?
By micflair in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 6Last Post: 12th Aug 2007, 06:16
