End goal: I have a DVD I want to extract the core movie, then burn it to another DVD so that the movie starts playing immediately without a menu.
I used DVD Decrypter to extract the VOB files.
I used IFOEdit to convert the VOB files to an IMG.
I used DVD Decrypter to burn the image to a DVD.
The DVD didn't work. WMP didn't recognize it and neither did other DVD software. Windows loads the created DVD as a data disc without any files.
I'd like to try other FREEWARE that can convert the VOB files to an IMG. Suggestions?
DVDFab HD Decrypter will do what you want ... load disc or video_ts folder on hd ... select main title only... output as iso... hit start and wait... play on pc prior to burning to media so as to check play back.
Does the free version of DVDFab HD Decrypter output an ISO file? I've had versions that did....and some that didn't.
The latest free versions don't allow it, if I remember correctly.
If cameras add ten pounds, why would people want to eat them? -
Rip the disc with DVDFab HD Decrypter, movie only to your hard disk then using DVDShrink convert it to ISO. Both programs are free.
The conversion to ISO only takes a few minutes.SONY 75" Full array 200Hz LED TV, Yamaha A1070 amp, Zidoo UHD3000, BeyonWiz PVR V2 (Enigma2 clone), Chromecast, Windows 11 Professional, QNAP NAS TS851 -
And as we all know, the DVD doesn't have to be converted to ISO in order to be burned. So you can save the convert to ISO step and just burn it after getting the main movie.
If this is just for burning, why dick with an ISO ? Just rip the movie only content to a video_ts folder, and if it fits, burn with imgburn in build mode by selecting the video-ts folder. Imgburn will set itself for DVD burning, and you are done.
I don't think any of the software you are using has been updated in the last 2 years.Read my blog here.
Convert ISO to VOB
By larrytxeast in forum Video ConversionReplies: 6Last Post: 23rd Jul 2010, 00:20 -
Creating ISO from VOB's
By chronic777 in forum Newbie / General discussionsReplies: 2Last Post: 19th Jul 2009, 13:36 -
Help with .vob and .iso convert? [not sure which forum]
By Penguinish in forum Newbie / General discussionsReplies: 7Last Post: 16th Feb 2009, 13:08 -
Iso and VOB conversion
By willmoodom in forum Newbie / General discussionsReplies: 5Last Post: 16th Oct 2007, 01:34 -
vob to iso?
By jree1 in forum Video ConversionReplies: 8Last Post: 20th May 2007, 11:12
