Hi. Im trying to convert a dvd to avi but I havent had any luck. When I use AutoGK, it gives out the wrong file size and the audio is way off track. Is there not a tool with step by step to get the job done right? I want the outcome to be HQ and AC3, TIA
Wrong file size? Post the log that was created during the encode.
Audio way off track? Which means what? That the audio is out-of-synch with the video? Is this a newer movie on DVD? If so, explain exactly how you decrypted the movie - how you got it onto the hard drive?
A step-by-step guide? How about the one included with AutoGK? Have you looked at that yet? Click on "About" on the main screen, and then on "Help". I don't think reading it is going to solve your problems though, if the problems are what I think they are. The log will provide some details.
DVD to AVC High Quality PSP Videos using Avi synth
By ppeterr in forum DVD RippingReplies: 12Last Post: 18th Jul 2010, 09:03 -
How To Produce High Quality WMV from AVI / DVD Files?
By devilcoelhodog in forum Video ConversionReplies: 3Last Post: 24th Jan 2010, 22:13 -
avi -> mpeg1 in high quality
By steve1401 in forum ffmpegX general discussionReplies: 5Last Post: 6th Nov 2009, 20:53 -
AVI(w/ High Quality) to FLV issue
By btmdan in forum Video ConversionReplies: 10Last Post: 8th Aug 2008, 11:35 -
Encoding RM to AVI (high Quality)
By hzgg2 in forum Video ConversionReplies: 2Last Post: 22nd Apr 2008, 15:11
