I am using Windows 7 x64 RTM. When I plug in the camcorder using firewire it recognizes the camera and installs drivers, claiming 'success'. However, it never offers to import the video. The camcorder shows up in 'devices', but it does not appear in 'autoplay' in the control panel.
I am unaware of a way to manually start the import software. I have always been under the impression that it would start automatically. On Vista x64 this was the case.
Any idea how I can get video off this camera to the hard drives?
Clay
I think lifespeed is refering to Windows AutoPlay. Unless changed, all Windows versions since XP will display a menu when a camcorder is detected. As with any AutoPlay feature, it can be permanently turned off or set to start an available application without prompting.Originally Posted by minidv2dvd
@lifespeed - if you want to use the built-in Windows capture, you can access it from within Windows Movie Maker though WinDV is a much more straightforward option especially if you are going to start things manually.John Miller
Sony DCR-HC24 on Windows 7
By slobadaca in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 26th Mar 2013, 09:41 -
streaming from camcorder sony dcr-hc42e to my windows 7 32bit laptop
By wfareed in forum Video Streaming DownloadingReplies: 6Last Post: 20th Oct 2010, 05:54 -
How do you fix a Sony dcr-trv315 handycam that won't record on tapes
By tyty66 in forum Newbie / General discussionsReplies: 0Last Post: 9th Oct 2010, 07:20 -
Sony DCR-TRV340 stuck on DV IN - help!
By MasterUnholyWar in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 3rd Mar 2010, 14:25 -
My PC won't recognize my Sony DCR-HC52?
By rogerwestberg in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 15Last Post: 31st May 2009, 17:17
