I have a set of PAL DVDs I am taking to .mp4 and I am getting jerky encodes. I kept everything the same. 720x576@25fps. My deinterlacer is Yadif. Why am I getting jerky videos when there is no frame rate conversion? Thanks.
Results 1 to 30 of 43
Why are you deinterlacing?
Very few movies on DVD are interlaced, only TV shows on DVD normally require deinterlacing. -
Sorry, these are cartoon DVDs from Australia produced by MadMan Entertainment. M.A.S.K.
Are you sure they were 25i to begin with?
Assuming what you say is true, If they were 25i to begin with, and you single rate deinterlaced (yadif mode=0) , you would get 25p
If you bobbed them (yadif mode=1), you would get 50p, and much smoother, but takes more bitrate to maintain same level of qualilty for 2x the number of frames
The other possiblity is that it is a playback problem e.g. slow pc (unlikely for standard def), decoder issues -
A sample might be helpful. Madman releases a lot of crappy NTSC2PAL DVDs.
And don't trust MeGUIs analyzer and script suggestions. Nothing beats your eyes. -
I am gonna give this a try. manono you are right. It is a crappy release. I am running most of the episodes thru TMPGEnc to give them some better color. I will get a sample ASAP. -MTT EDIT: How many seconds of video sample would you like manono?
tdeint(mode=2,order=-1,full=true,field=-1,mthreshL=-1,mthreshC=-1,type=4,sharp=true,mtnmode=2,cthresh=10,blim=-1,metric=0,slow=2).EEDI2(field=1,pp=0).selectevery (2,0) -
Yeah, it's fieldblended from an NTSC film source. It doesn't need deinterlacing but unblending:
Yadif(Mode=1,Order=1)
SRestore(Frate=24)
http://avisynth.org/mediawiki/Srestore
http://forum.doom9.org/showthread.php?t=95924
it is pretty crude animation, so it'll always play a bit jerky. -
Thanks again for your insight. I don't mean to question what you wrote but is
SRestore(Frate=24) supposed to be SRestore(Frate=25) since I am not going from PAL to NTSC. I am keeping everything as it already is. 720x576@25fps -
The 'base' framerate is 24fps. If this is to be reencoded for PAL DVD, encode for 720x576 at 24fps and then run the resulting MPV through DGPulldown set for 24->25fps. After that it'll be PAL DVD compliant and ready to author. If, as you said, it's for MP4, then what's wrong with encoding at 24fps? That's what it was before Madman got its grubby paws on it. There is no PAL or NTSC MP4 (x264 or whatever) video. You can use the original audio without stretching it. The video's length remains the same.
I am not gonna reencode to PAL DVD. My process is Rip, run the .vob thru TMPGEnc if it needs some color adjustments then save as mpeg2. Create a d2v file then encode with MeGui to mp4. I was concerned with audio/video sync issues if I tinkered with frame rates. EDIT: I just read your post again and saw you mentioned the audio won't matter. I will give it a shot. Thanks again. I will post the results here.
I am concerned yes but I might have to live with it. The colors on most of these toons are pretty dull. In TMPGEnc I am Color Correcting using YUV adjusting Chroma and Gamma. Those help boost the colors how I like. If I could do the exact same thing and go to Huffy I will. I just don't know how. EDIT: Hey what do you know. TMPGEnc will export to Huffy.
Would it look like this for what I need to do?
ColorYUV(chroma=75)
ColorYUV(gamma_U=30)
I am reading about ColorYUV() and this is way over my head. -
I don't know how TMPGEnc's adjustments translate into ColorYUV() arguments. There's no chroma argument so you have to adjust U and V separately:
ColorYUV(cont_u=75, cont_v=75) #increase saturation
The values to use will almost certainly be different than in TMPGEnc. I suspect TMPGEnc is 100 based (for example brightness 100 will double the brightness) whereas AviSynth is 255 based. You can use AvsP to make adjustments a little easier -- it has a quick preview by pressing F5.
You might find Tweak() easier to use. -
jagabo: I was assuming AviSynth's ColorYUV would do what I could do with YUV in TMPGEnc. In TMPGEnc I can make the orange, red and blues brighter. Also back the the topic of this thread I just finished an encode with
Yadif(order=1, mode=1)
SRestore(Frate=25) and I am still getting the jerks. I will use SRestore(Frate=24) now. When the scene is panning it jerks about ever 1/2 second. I can live with I guess. -
When I wake up in 3 hours I will give this a shot to see if there is no jerks in the video. I found this in an old script I had made a few years ago for the same toon. The play was smooth using it.
FieldDeinterlace(blend=true,threshold=7,dthreshold =7) -
Originally Posted by MegaTonTerror
Also, check the field order. Your sample was TFF, but the whole thing doesn't necessarily have to be TFF (although it probably is). There's a chance you reversed the field order when cutting a piece.
Tweak(Sat=1.2,Coring=False)
does something like you want. That's saturation, and it strengthens all the colors. For working with the individual colors in AviSynth it's RGBAdjust and ChannelMixer. To use either of them you convert to RGB. But then so does TMPGEnc. -
Good Morning manono. Update: I used the following...
SRestore(Frate=24)
Tweak(Sat=1.45,Coring=False)
Everything came out great. There was minimal to no jerks in the video. The .45 may have been a little to much on the red so I will kick it down to .35 or .4. Thanks again for the advice. Using Tweak and getting those results will allow me to skip the TMPGEnc process and save me 3 days worth of time.. literally. -
I find it hard to adjust colors in YUV. Off_v=-10 will decrease red but it will increase green. If you try to compensate by adding off_u=10, greens will come down but blue will go up.
Originally Posted by jagabo
A useful tool would be a program that lets you adjust colors in RGB then translates that to YUV equivalents.
Bitrate vs Size Calculator for x264 for ripping DVD to x264 + AC3
By Bonie81 in forum DVD RippingReplies: 7Last Post: 5th Jul 2010, 18:24 -
Color problem with x264 output + other x264 questions
By serexl in forum Newbie / General discussionsReplies: 3Last Post: 15th Mar 2010, 18:31 -
x264: -1920, -ESiR, -SEPTiC, -CiNEFiLE.... What are these x264 extentions?
By NWNewell in forum Newbie / General discussionsReplies: 7Last Post: 18th May 2009, 17:10 -
Best tool for PAL to NTSC without jerky motion...using TMPGenc
By funkymix in forum Video ConversionReplies: 3Last Post: 15th Mar 2009, 11:59 -
Video is Jerky after NTSC DVD to PAL VCD Conversion.
By milindb1 in forum Video ConversionReplies: 14Last Post: 10th Sep 2008, 02:22
