I have tried everything and I just don't understand what I'm doing wrong.
Here's what I do:
I have a video player which is plugged into my DV camera, which is plugged into my firewire. That is the setup I've had for several years. After capturing (using DV type-1), I then go into virtualdub and do any editing that may be needed. I then use Virtualdub's frame server and use CCE to encode the video. As far as I'm aware and from all the guides I have read, I have the settings in CCE correct for encoding from a DV source. I have changed settings several times to see if it made a difference and it didn't. When it has encoded, I make my DVD's, but they flicker heaps! Usually when there is fast motion and/or many colours.
Please help, it's driving me insane! Just can't seem to fix the problem!
Many thanks in advance![]()
Results 1 to 12 of 12
dvd is interlaced. have you perhaps changed the field order? DVavi is bff, did you encode it to mpeg-2 tff?
If the "flicker" is motion related, then it is a field order issue. Encode the DVD bottom or lower field first.
http://www.kiva.org/about -
Ok, thankyou both for the info. I have tried bff and tff and still get the flicker. As the footage is interlaced, should I not click "progressive frame"? Also I read that I should set Block Scanning Order to "Alternate".
Not progressive if for DVD.
In virtualdub, use the Cedocida DV Codec set to YCbCr etc. Then frameserve to CCE or export DV or uncompressed YCbCr to a file and import that.
You have chozen a complicated way to cut edit DV format.
If you need to deinterlace for some reason, best to do it in avisynth.Recommends: Kiva.org - Loans that change lives.
Virtual dub uses a DV codec to convert DV to uncompressed RGB or YCbCr and then recompresses on export. Best way is to frameserve uncompressed lower field first YCbCr to the encoder. I don't have CCE installed so can't go into more settings detail.Originally Posted by Duck_Plumber
Others will help.Recommends: Kiva.org - Loans that change lives.
Damn this! I STILL can't stop my dv footage from flickering when converted to dvd! I've tried everything!
If you editing does not involve cropping or filters then you can use Direct Stream Copy to pass the edited footage back to your HDD as DV AVI without re-encoding. You can then use a simple Avisynth script to pass it to CCE.
If you want to see if your CCE settings are the issue, use AVStoDVD to encode the edited footage using HCEnc, and see if the flicker persists.Read my blog here.
Plasma flickers when used as a monitor
By joe7dust in forum DVB / IPTVReplies: 16Last Post: 26th Nov 2012, 13:42 -
converted sports footage - How best to handle ?
By davexnet in forum Video ConversionReplies: 5Last Post: 28th Oct 2010, 15:45 -
footage from 5d Mark II mixed with XLII footage
By segan in forum Newbie / General discussionsReplies: 2Last Post: 13th May 2010, 14:24 -
Black upper stripe flutters / flickers
By dynamique in forum Authoring (DVD)Replies: 0Last Post: 26th Sep 2007, 06:05 -
Video Footage, Rotating the footage.
By nikon1898 in forum EditingReplies: 2Last Post: 14th Jun 2007, 04:54
