Hi gurus,
I am planning to buy a VCR which I will be using to capture video from my VHS tapes through Dazzle DVC. Can you suggest a good VCR to buy for this purpose? Is the S-Video output
necessary - is it worth the extra money that I will pay?
My budget is $150.
Thank you.
regards,
smr
My suggestion would be a VCR with Super VHS ET (JVC). Super VHS ET achieves the higher resolution (400 lines) using standard VHS tapes. You won't have to buy the expensive SVHS tapes and your old tapes will work as well.
Specific Panasonic VCR buying advice needed
By Sainsbo_McManus in forum RestorationReplies: 8Last Post: 28th Nov 2011, 20:30 -
Restoration project: Need advice buying a decent VCR.
By nicknick in forum RestorationReplies: 35Last Post: 12th Apr 2010, 11:14 -
DVD/VCR RECORDER WITH USB PORT seeking
By neorican in forum DVD & Blu-ray RecordersReplies: 4Last Post: 12th Oct 2009, 13:24 -
Seeking Advice | Which Player for Europe?
By ntarantino in forum DVD & Blu-ray PlayersReplies: 9Last Post: 22nd Sep 2008, 08:25 -
Newbie seeking some advice, please. :)
By Gun in forum Authoring (DVD)Replies: 18Last Post: 3rd Jul 2007, 20:07
