I have an .avi that was given to me, not ripped by me. I can play the file fine w/ Win media plyr but I an trying to convert to an mpeg to vcd it. When I try to open the .avi in TMPGEenc, I get an error similiar to "could not open file, or unsuppoorted file". Tried another app, VirtualDUB I think its called, and it too gave an error but with more detail. The error was to the effect of could not find decompressor for "MP43 - Microsoft High-Speed Codec v4". I have successfully used avi2mpg v4 to convert the avi to mpg and vcd however there are no output resolution/screen size options in avi2mpg so I need the advanced features of TMPGencs output. Does anyone know a way I can get these .avis to open in TMPGenc ?? Tried for several hours with several apps, not much luck here....The MP43 decompressor codec seems to be the problem. Please advise. Thanks !
-MjN03
MP43 is a specific codec (similar to ASF/WMV but not streamable)
I got the codec here (when I had to reinstall on one of my computers the other day)
http://video-codec.8m.com/codecs.htm
any number of codec sites will have it for download - it originally came from MS in the Windows Media Encoder 7 package ... you still might be able to get it from MS ... but I'm not sure
rule of thumb - if you can't open an AVI - drag it into VirtualDub and the error message will tell you what codec to find and install - a simple search in google will usually do ityour pal,
Stinky
Machete 3.8 is released - MOV (Apple QuickTime) format now supported
By MacheteSoft in forum Latest Video NewsReplies: 0Last Post: 7th Dec 2011, 12:18 -
File format not supported on mp3 adobe premiere cs3
By afrojavi in forum EditingReplies: 2Last Post: 26th Apr 2010, 05:35 -
InterVideo WinDVR 3: "The specified capture format is not supported on
By SignedupGuest in forum Newbie / General discussionsReplies: 1Last Post: 17th Sep 2008, 19:01 -
Help Friend! How to read subtitle file on my dvd player (not divx supported
By justin1983 in forum SubtitleReplies: 17Last Post: 26th Jan 2008, 11:42 -
MKV to any Quicktime-supported format - for Mac
By brijazz in forum User guidesReplies: 2Last Post: 8th Aug 2007, 17:07
