My questions has 2 parts.
1st- Does anyone knows how a way to burn a VCD with a modified or ecrypted movie, so when we put it on the DVD player it will ask for a password after begginind menus, presentations, movies, .... And if we try to play the movie in a computer using windows media player we will not be able to?
2ndt- Same case, but movie not need to be modified or encrypted and can be played on windows media.
1st question is what I really look for but if anyone knows the 2nd question answer it would be very nice also.
Thanks,
Fred
You can make a "password" type menu but if your movie is burnt as a video track (it should be), then it can all be bypassed by turning off PBC.
You can't encrypt the movie and have it viewable on a stand-alone player.
If you put your movie as a segment-item rather than a track (decreased play length), the menu will be effective in stopping the PBC-off trick but anyone will still be able to play the video on the PC.
Regards.Michael Tam
w: Morsels of Evidence -
Originally Posted by CJGS
Its fairly simple dont lend your disks then no one can copy them sounds logical doesnt it.
its even easier than copy protecting them
Protecting a dvd from being copied
By arnold.iceman in forum Authoring (DVD)Replies: 4Last Post: 14th Aug 2010, 09:12 -
Copy Protecting an Image CD/DVD
By Squid_uk in forum Newbie / General discussionsReplies: 36Last Post: 19th Mar 2010, 14:15 -
Protecting My Own Videos From Copying
By moviebuff2 in forum Newbie / General discussionsReplies: 57Last Post: 6th Dec 2007, 15:48 -
DVD-Protecting
By josh22_22 in forum Authoring (DVD)Replies: 9Last Post: 7th Aug 2007, 22:50 -
Protecting DVD
By adamstillwell in forum Newbie / General discussionsReplies: 9Last Post: 30th Jul 2007, 01:48
