Hi
I tried using IFO edit to create a DVD from 3 vob files. However, when I play the DVD, the original chaptering is gone. How can I create a totally new chapters so that I can play in my DVD players.
Advance thanks for your advice.
Results 1 to 9 of 9
You create chapters in ifoedit by adding a celltimes.txt,it displays like this:
The numbers you see are the frames in the movie,google for more info about it.Code:5927 8854 21180 24610 27722 33218 34448 39021 40319 45475 51403 55056
i have been googling . But i am a little bit confuse. How do i load the video in IFO edit ? I have 3 vob files. i have the "celltimes" ready. but how to put them into thress differnt bvob. I really do not how. can u provide me the guide link ? i need a step by step guide.
Basically i have a VIDEO_TS with vob and IFO but no chaptering. Therefore i cant forward or backward the video.
Please help . Thanks -
Use VOB2MPG to extract the video and audio data from the VOBs into MPG files. Use DVD Styler to properly author. Far simpler than IFOEdit in the long run.
Read my blog here.
If you're authoring in 'Create IFOs', you can't add chapters. You'll have to use IFOEdit's reauthoring section (DVD Author->Author New DVD). Better would be to use Muxman which takes video, audio, and chapters in the same format as does IFOEdit.
Demux your VOBs (DGIndex is one way- File->Save Project and Demux Video), then add in the M2V and audio that was created. The Celltimes.txt is created in the frame number format as described by johns0. It's 25fps if for PAL and 29.97fps if for NTSC. -
hiOriginally Posted by guns1inger
why do u need to demux to mpg before authoring ? Isnt vob file also a video file. why cant we do a chaptering in vob file .
sorry for being newbie.
thanks -
Are the VOB files from the same titleset ?
Are they the complete titleset ?
Personally, I find that taking VOBs from point A to point B and trying to create a new disc is often more trouble than it is worth. It is a simple step to get the contents back to either a program or elementary streams and author a new disc. This way I know what I have, rather than hoping that what was in the VOBs is actually stable and correct.Read my blog here.
Here my answer :
Yes.
No.
Actually i tried to rip my DVD. It has 3 VOB files. But while ripping the 3rd VOB files, my pc cant read the disc. Now i left so called 2.5 VOB file which i wanna to build them to a DVD.
I used IFO edit to built the video with DVD compliance, however without chaptering. Without chaptering is very difficut for my son to watch the video as there are lots of episode in the video and he like to swtich chapter from chapter.
How do I make a dvd data disk from these vob, bup, and ifo files?
By DHarry in forum Newbie / General discussionsReplies: 4Last Post: 4th Jul 2011, 04:23 -
Burning VOB files to DVD WITHOUT Menus Or Chapters
By mediachimp in forum Authoring (DVD)Replies: 5Last Post: 11th Aug 2010, 01:11 -
How do you make a DVD from only some VOB & IFO files?
By JoeBolden in forum DVD RippingReplies: 3Last Post: 12th Mar 2009, 00:12 -
Make a DVD from VOB files
By jmsrickland in forum Newbie / General discussionsReplies: 5Last Post: 6th Aug 2008, 19:30 -
question about VOB compliant files to make DVD
By jimdagys in forum Authoring (DVD)Replies: 3Last Post: 25th Nov 2007, 01:05
