Just the basics of my pc setup below I also own a WD 1080P Media Player but I get the same results with any 1080p content that I download 720p just works fine.
Win 7 Ultimate
Sharp 52" 1080p 120Hz Panel connected dvi2hdmi cable
Intel 805D processor watercooled OC to 4.00Ghz
2x WD Raptors Raid 0
2Gig OCZ 667 Memory
Geforce 8800GTX
WD1080p Player with current firmware and a sony hdmi cable
My problem is video lags at times and audio isn't in sync what suggestions do you have for media players to use on my pc ive tried vlc, mpc, kmplayer or is it that neither my pc or this western digital media player will play 1080p rips thank you for your time.
Welcome to the forums, but as is often the case with new members, you're not telling us enough to help you.
What's the audio format of the files? Is it DTS? What container is the file? (MKV? Something else?) What's the frame rate of the video? A tool like GSpot or something similar might be of help here.
The WD generally plays 1080p fine, but DTS can be challenging. It could just be that nothing can play these files correctly because whoever made them screwed up. I'm not familiar with your processor, so I don't know if your PC is fast enough for 1080p video or not. -
You need either a multithreaded h.264 decoder or hardware h.264 decoding for smooth playback of 1080p. ffdshow mt has a free software decoder. You can also use CoreAVC Pro (not the non-pro version). Recent versions of MPCHC have a multithreaded build of ffdshow internally.
Your graphics card has hardware h.264 decoding. MPCHC supports the feature. Go to View -> Options -> Internal Filters -> Transform Filters, and enable H264/AVC (DXVS) for hardware decoding, or H264/AVC (FFmpeg) for software decoding. If you use the software decoder double click on it to bring up the config dialog and set the Decoding Thread Number to 2. The hardware decoder, DXVA, will not work on all h.264 sources.
Hardware Requirements for 1080p Playback?
By therock003 in forum Software PlayingReplies: 17Last Post: 16th May 2011, 07:37 -
Shrinking 1080p MKV, change to 720p or keep as 1080p?
By Phat J in forum Video ConversionReplies: 5Last Post: 28th Nov 2010, 10:35 -
1080P MKV playback issue
By nekromantik in forum Software PlayingReplies: 15Last Post: 14th Jan 2010, 17:40 -
HDV 1080p Im Looking for 1080p HDVs.
By ChristianPaprika in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 19Last Post: 16th Nov 2008, 22:05 -
Slow MKV 1080p Playback!
By The_WRATH in forum Newbie / General discussionsReplies: 3Last Post: 19th Aug 2008, 14:50
