I have used TMPGEnc several times successfully to convert an avi to a VCD compatible MPG using the guides. However, I've run across a particular avi file that is 242MB but when converting it, it creates an MPG files in excess of 1.5GB (running out of disk space so the process bombs out before I actually get to see if it finishes). I'm using the same settings as always and have converted other avi's since, but have tried a few times unsuccessfully on this file. - Thanks
OK - FYI - found a workaround to whatever was the reason for the problem. I used the decompress utility that came with the avi2vcd 1.4.1 beta to create an "uncompressed" (I guess) avi file (it was about 700MB). Then used TMPGEnc to create the VCD-compatible MPG which came out about 450MB (I used avi2vcd 1st but the sound was out of sync with the video). So not sure exactly what the issue was - but fumbled my way around it......
creating many small clips w/ mpeg ts file
By Funkymoses in forum Newbie / General discussionsReplies: 1Last Post: 6th Sep 2010, 12:53 -
PROBLEM: AVI -> MPG by using TMPGEnc 4.0 XPRess (4.2.3.193)
By Hummelchen in forum Video ConversionReplies: 0Last Post: 14th Jun 2010, 07:10 -
creating small mpeg with delay between frames
By nighthawk2018 in forum Newbie / General discussionsReplies: 11Last Post: 30th Dec 2009, 10:56 -
2 Small-ish AVI -> 1 Larger AVI = HUGE File. Why?
By cxp36 in forum Newbie / General discussionsReplies: 2Last Post: 6th Mar 2008, 18:31 -
TMPGEnc not working.. what else is good for avi to mpg?
By andre477 in forum Video ConversionReplies: 10Last Post: 21st May 2007, 02:52
