Hi,
I had been using WinAVI for awhile. I understand that there's an option which i could enter to indicate the maximum output size i desired. I had been converting rmvb files to DVD setting a limit of 4.7gb. However, lately i had been converting new files which exceeded the limit, instead of creating just one folder "DVD_01_1", it creates another folder "DVD_01_2".
Is there any ways i can keep it within the 4.7gb limit? It kept exceeding :\
Any help will be appreciated. Thanks![]()
Results 1 to 22 of 22
Hmm, i tried the prog. Placed the videos there but the resulting output exceed 4.7gb as well..
Use DVD Shrink to pull it down to the required size. You might lose a bit of quality doing so, but since you are going from one compressed format to another with your original conversion, it really doesnt matter.Originally Posted by AkusaiYou are in breach of the forum rules and are being banned. Do not post false information.
/Moderator John Q. Publik -
Hmm.. each file is around 300MB, 43mins. I placed 6 files in. Previously i had been using Convertxtodvd, it worked pretty well for 1yr+ or so but now i can't convert the rmvb files with them now.. Thus i tried out WinAVI but it kept exceeding 4.7gb.. so i'm trying to find a new prog which is able to replace them
More than 4 hours. It's a lot. But we can come out using AVStoDVD.
1. Go to 'Preferences'/'AudioVideo'
2. Change 'Video Lower Avg BitRate' from 2500 to 500 kbps
3. Press OK (save as default if you want)
4. Load your 6 titles
5. Encode
Let me know
Bye -
It fails to convert.. any idea why?<10/1/2009 9:36:30 PM>
START PROCESS
PROJECT SETTINGS
DVD Video Standard: PAL
DVD Titles number: 6
DVD Size: 4435/4435 MB (100%)
DVD Output Setup: DVD Folder
DVD Label: DVD
DVD Menu: No Menu
Output Folder: C:\Documents and Settings\Akusai\Desktop
Save Log file: Yes
Delete Temp Process Files: Yes
Delete Working Files: Yes
Edit Command Parameters: No
Post Process Task: Show Progress Status window
TITLE 1 SOURCE FILES
Video: D:\yyzf1\7.rmvb
Info: RealVideo 4 - 864 kbps - 512x384 - DAR 1.333 - 25 fps - - 43:41 minutes - 65541 frames
Audio: D:\yyzf1\7.rmvb
Info: AAC-LC - 96 kbps - - 44100Hz - 2ch - 43:41 minutes
Subs:
[MediaInfoLib - v0.7.19]
AVISYNTH SCRIPT
Import("C:\Program Files\AVStoDVD\Lib\A2DSource.avsi")
Video = A2DVideoSource("D:\yyzf1\7.rmvb", CacheFolder = "C:\DOCUME~1\Akusai\LOCALS~1\Temp")
Audio = A2DAudioSource("D:\yyzf1\7.rmvb", CacheFolder = "C:\DOCUME~1\Akusai\LOCALS~1\Temp")
Video = Video.ConvertToYV12
Video = Video.Lanczos4Resize(720,576)
Audio = Audio.SSRC(48000)
AudioDub(Video, Audio)
START VIDEO ENCODING OPERATIONS
Encoding Profile: HCenc VBR 2-pass
Target Video FileSize: 590.4 MB
HCenc Parameters: -ini "C:\DOCUME~1\Akusai\LOCALS~1\Temp\DVD_0_Title_01_7 .HCenc.ini"
HCenc ini file:
*INFILE C:\DOCUME~1\Akusai\LOCALS~1\Temp\DVD_0_Title_01_7. avs
*AVSRELOAD
*OUTFILE C:\Documents and Settings\Akusai\Desktop\DVD_0_Title_01_7.m2v
*LOGFILE C:\DOCUME~1\Akusai\LOCALS~1\Temp\DVD_0_Title_01_7. HCenc.log
*MAXBITRATE 9000
*BITRATE 1889
*PROFILE BEST
*ASPECT 4:3
*PROGRESSIVE
*BIAS 20
*DC_PREC 8
*MATRIX MPEG
*AQ 1
*LUMGAIN 0
*SMP
*PRIORITY IDLE
*WAIT 2
<10/1/2009 9:37:04 PM>
PROCESS ABORTED DURING TITLE 1 VIDEO ENCODING OPERATIONS.
CHECK LOG FILE <C:\DOCUMENTS AND SETTINGS\AKUSAI\DESKTOP\DVD_0.LOG> FOR MORE INFO.
Log file created by AVStoDVD Release 2.2.1
Do you have installed a proper directshow codec to decode the rmvb file? If you can play the file with Windows Media Player (or the internal AVStoDVD 'Preview Clip'), you had, if not, you should do.
Bye -
Yeah, use the links in the menu on every page of this site, specifically "TOOLS" then "CODECS"Originally Posted by Akusai
Hmm.. i can't really view the vids using the in-built player. I can hear the audio but the screen remains grey..
Hmmm.. it says,
"DirectShowSource: I can't determine the frame rate of the video, you must use the 'fps' parameter.
(C: DOCUME~1/myusername/LOCALS~1/Temp/AviSynthP.avs, line 1)" -
Ok, let's stay with DirectShowSource.
Now go to 'Edit Title'/'AviSynth' and toggle off 'Auto AviSynth Script'. Locate line with DirectShowSource function call. It should be something like:
and replace it with:Code:Video = DirectShowSource("D:\yyzf1\7.rmvb", convertfps=true, audio=false)
Script will become red because of editing. Press OK and try again with built-in previewer.Code:Video = DirectShowSource("D:\yyzf1\7.rmvb", fps=25, convertfps=true, audio=false)
Bye -
^Yup it works now, and i'm able to convert the vid, thanks so much!!
Just another question, do i have to keep editing the avisynth all the time whenever i'm converting the same types of rmvb files?
Edit: There are several rmvb files that i tried using the above method, it gave the following error msg:
"Directshowsource: RenderFile, the filter graph manager won't talk to me
(C
OCUME~1/myusername/LOCALS~1/Temp/AviSynthP.avs, line 2)"
Until AVStoDVD next release, yes.Originally Posted by Akusai
Usually that type of error happens when codecs are missing or when there is a codec conflict (i.e. when more than one directshow decoder is installed).Originally Posted by Akusai
Bye
How to get output file size before converting a file using ffmpeg?
By hayden in forum ProgrammingReplies: 1Last Post: 26th Feb 2012, 08:04 -
avs (avi to avi) ends up out of sync ... winavi output file too big
By mandy in forum Video ConversionReplies: 1Last Post: 21st Aug 2009, 06:56 -
different output file size in convertx2dvd
By Iwan2learn in forum Authoring (DVD)Replies: 13Last Post: 13th May 2009, 03:29 -
Video Conversion - output file size
By Leo48 in forum Newbie / General discussionsReplies: 2Last Post: 19th May 2008, 08:28 -
Controlling CCE's output file size.
By astrocity20 in forum DVD RippingReplies: 24Last Post: 13th Dec 2007, 23:32
