hi all
today i Bought a new pc wit these specifications
mother board:intel35i
vga card:ati 1 gb
ram:6 gb
HD: only 500 gb and i have extenal 500 gb
i think its not a bad 4 home working (capturing...editing...)
it costs around 550$ but i still thinking of adding another vga card and 2 gb ram
and thanks alot
	Unless you are running a 64bit operating system, about 4GB RAM is all it can use with a 32 bit OS. Over 4GB isn't accessed  If you have Vista 64 or XP 64, you can run just about all you want. But it likely won't speed up encoding or editing much if at all. But if the PC came with 6GB RAM, it's probably a 64bit OS. If you have Vista 64 or XP 64, you can run just about all you want. But it likely won't speed up encoding or editing much if at all. But if the PC came with 6GB RAM, it's probably a 64bit OS.
 Video cards are mostly for playback. Some newer ATI and Nvidia video cards have hardware acceleration and can assist with the video processing and encoding, freeing up some CPU power. If you use the PC for gaming, then a faster video card will help those applications a lot.
	So... what kind of CPU is there? A dual core? Intel? AMD?
 What kind of graphics card?
 The exact names will tell if the PC is any good for video/gaming or not.
 By the way, the price is cheap for any power PC.
	Yes, but is it a 64-bit OS ? Want my help? Ask here! (not via PM!)
  RipBot264 - Need help badBy minks in forum Video ConversionReplies: 7Last Post: 21st Dec 2010, 21:54
  bad clipsBy zoobie in forum RestorationReplies: 0Last Post: 26th Nov 2010, 03:41
  No Audio In Encore/Bad Aspect Ratio/Bad Files/Bad ISO/Bad EverythingBy koberulz in forum Newbie / General discussionsReplies: 35Last Post: 24th Jan 2010, 05:48
  Bad motherboard or bad CPU?By videohalp in forum ComputerReplies: 11Last Post: 9th Jul 2008, 11:07
  Bad encoding? Bad installationBy lo-q in forum ffmpegX general discussionReplies: 2Last Post: 22nd Sep 2007, 20:45
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
			 Visit Homepage
				Visit Homepage
