Results 1 to 13 of 13
  1. I have one problem with something that AVG notifies me:
    What can it be? Can I remove it?
  2. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    Run your cleaner with your computer in SAFE Mode. Easiest way to get to SAFE Mode is BootSafe.
    http://www.superadblocker.com/bootsafe.html
  3. It doesn't get much easier than pressing F8 at boot time and selecting Safe Mode from the menu.
    You also could try a registry cleaner like CCcleaner, and a second AV program like MalwareBytes.
    Also, what happens when you select the two files and clean them?
    canada
    Remove it now,its just in the restore files and turn off restore,reboot and then turn restore back on again.
  5. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    Yea it does....it's called Bootsafe.
  6. mbam.exe is the malwarebytes program. why avg doesn't like it i don't know.
  7. I'd be really worried if your computer can't even post properly to this website.
    Note disappearing words in screenshot 2 (Firefox) and screenshot 3 (Internet Explorer).
  8. hehe - jimdagys that problem is all at your end not his.
    his jpg and the link displays/works fine, that's what the url /url is.
  9. Banned
    Jun 2004
    ®Inside My Avatar™© U.S.
    He forgot to put on his aluminum foil hat 8)
  10. Video Restorer lordsmurf's Avatar
    AVG became crap with version 8.
  11. Originally Posted by lordsmurf
    yeah i agree with that. avast is the only decent free a/v i've seen for a while now. the ui is atrocious, but the scanner is fast and very good.
  12. Banned
    Aug 2002
    beautiful
    NOD32!
    (I know I have said it many times...)
  13. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    NOD32!
    He also said FREE.
