Ok. I have a sample file of larger file i am getting as i am typing this. Below is the specs on the sample file. My question is what is best way to go about making it PS3 compatible and keeping it as pure as possible. I have DTS receiver. But would like to be able to play on TV alone too without receiver. The video is fine. It's the audio i need help with. Any replies would be greatly appreciated. Thank you.
ORIGINAL FILE:
Format : Matroska
File size : 78.0 MiB
Duration : 1mn 25s
Overall bit rate : 7 653 Kbps
Encoded date : UTC 2009-09-26 08:43:08
Writing application : mkvmerge v2.9.7 ('Tenderness') built on Jul 1 2009 18:43:35
Writing library : libebml v0.7.7 + libmatroska v0.8.1
Video
Format : AVC
Format profile : High@L4.1
Format settings, CABAC : Yes
Format settings, ReFrames : 12 frames
Muxing mode : Container profile=Unknown@4.1
Codec ID : V_MPEG4/ISO/AVC
Duration : 1mn 25s
Bit rate : 5 990 Kbps
Width : 1 280 pixels
Height : 534 pixels
Display aspect ratio : 2.35:1
Frame rate : 23.976 fps
Resolution : 24 bits
Colorimetry : 4:2:0
Scan type : Progressive
Bits/(Pixel*Frame) : 0.366
Stream size : 61.0 MiB (78%)
Title : Video: x264_L4.1 @ 6000 Kbps
Language : English
Audio
Format : DTS
Format/Info : Digital Theater Systems
Codec ID : A_DTS
Duration : 1mn 25s
Bit rate mode : Constant
Bit rate : 1 510 Kbps
Channel(s) : 6 channels
Channel positions : Front: L C R, Surround: L R, LFE
Sampling rate : 48.0 KHz
Video delay : 4ms
Stream size : 15.4 MiB (20%)
Title : Audio: English DTS 5.1 @ 1509 Kbps
Language : English
Maybe convert to ac3 using PopCorn MKV AudioConverter .
Thanks Baldrick. what container should i use? I just used MKVtoVOB and got the results below. Is this gonna be best quality I can get? Or would u suggest some other way to get best result? And of coarse it's .mpg file.
Format : MPEG-TS
File size : 71.7 MiB
Duration : 1mn 25s
Overall bit rate : 7 039 Kbps
Maximum Overall bit rate : 35.5 Mbps
Video
Menu ID : 1 (0x1)
Format : AVC
Duration : 1mn 25s
Bit rate : 5 911 Kbps
Height : 534 pixels
Colorimetry : 4:2:0
Bits/(Pixel*Frame) : 0.361
Stream size : 60.1 MiB (84%)
Audio
Menu ID : 1 (0x1)
Format : AC-3
Format/Info : Audio Coding 3
Duration : 1mn 25s
Bit rate : 640 Kbps
Stream size : 6.52 MiB (9%) -
Try this guide:
http://www.afterdawn.com/guides/archive/how_to_play_mkv_content_on_playstation_3 _ps3.cfm
Just need TSmuxer and MeGUI. Three steps and done. Just remux it in M2Ts format with AC3 instead of DTS and it'll play on the PS3.
[Help] Blu-Ray > MKV > Hardcoded Vid & Sub > MKV > PS3
By psionicsin in forum Newbie / General discussionsReplies: 2Last Post: 3rd Mar 2011, 02:07 -
Problems converting recent mkv's to ps3 format!??
By josetjr in forum Video ConversionReplies: 1Last Post: 25th Sep 2010, 06:15 -
Recommended Format? Digital8 video to PS3 or PC format?
By fuzzysword in forum Video ConversionReplies: 5Last Post: 26th Apr 2010, 07:19 -
How to convert mkv to ps3 viewable format maintaining mkv subs in new file?
By shuyinliquid in forum Video ConversionReplies: 2Last Post: 14th Dec 2009, 01:17 -
MKV to PS3
By WinSpecToR in forum Video ConversionReplies: 3Last Post: 10th Aug 2008, 15:38
