Hey guys,
I've recently had an avi video file compressed using WinRar, the problem is that I compressed it twice and now it doesn't work anymore. Well, the audio works fine but the video doesn't play. I've tried using Windows Media Classic and VLC which worked for the file just fine up until i compressed the file. I used a program called G-Spot to identify if I was missing any codecs but it says that there was a partial render failure, more specifically , the audio could be rendered but the video could not. Is there any way to fix this? Any help appreciated!
why did you compress it twice? you don't get extra compression
try winrar's repair function -
Well, I planned to store the file in my hard disk for a long time, I thought it might be more secure for some reason. Yes i have tried using the repair function but don't think that it works, it comes up with a rebuilt copy of the file but the results after extraction is the same. This might not be note worthy but winrar did stop responding a few times while i was trying to repair it, the audio works fine but somehow the video just gets 'cropped out'
Corrupt DV Avi file
By Briansquest in forum Video ConversionReplies: 2Last Post: 15th Jul 2010, 13:01 -
Corrupt AVI file
By wahwill in forum RestorationReplies: 8Last Post: 9th Feb 2010, 00:19 -
Corrupt AVI File
By thankyou in forum Video ConversionReplies: 35Last Post: 18th Oct 2007, 03:19 -
Corrupt Frame on avi file
By thankyou in forum RestorationReplies: 1Last Post: 2nd Oct 2007, 21:58 -
swf to avi but it might be corrupt?
By leffe in forum Newbie / General discussionsReplies: 0Last Post: 22nd Sep 2007, 13:52
