Hello
Are there DVD players out there which play OGM files?
I plan to put 4 episodes on DVD (Xvid) what would the optimum size be for each 40min episode? would I be able to fit more than 4 episodes on one DVD or am I better off sticking to just 4?
I've never heard of any. MKV support is what consumers want and where the industry seems to be headed.Originally Posted by BlundaKat
About 1 GB per episode. You could consider going up to 1.1 GB, but you're not likely to notice any difference. I'm not sure I'd recommend that as 4.4 GB (4 x 1.1 GB) is going to be pushing the maximum capacity of single layer DVD and some people have reported problems with discs that are close to the maximum capacity. 1 GB per episode avoids that problem.Originally Posted by BlundaKat
Yes, you can fit more episodes on a disc, but the quality will be worse. I wouldn't do it, but you're the person who has to decide if lesser quality is OK, not me.Originally Posted by BlundaKat
Standalone player will not play DVD
By Chala in forum Newbie / General discussionsReplies: 12Last Post: 16th Sep 2010, 03:09 -
HT - dvd player in the pc or a standalone?
By Haopengyou in forum Media Center PC / MediaCentersReplies: 5Last Post: 6th May 2010, 07:39 -
Best and cheapest standalone DVD player
By riahc3 in forum DVD & Blu-ray PlayersReplies: 20Last Post: 1st Jul 2009, 08:35 -
DVD playing in standalone player but not on PC
By Leo48 in forum Newbie / General discussionsReplies: 2Last Post: 28th Jun 2008, 09:35 -
Problem with playing DVD in standalone player
By tngolfn in forum Newbie / General discussionsReplies: 2Last Post: 14th May 2007, 17:41
