Hi guys,
I downloaded this program on my home computer and have had no problems with it. However I have had the IT guys install it on my work computer to convert a few vids for work and I can't even to get it to load a video.
Basically I go to open video, select desktop to retrieve it from and it doesn't recognise the AVI file I have on the desktop as a video file, so it won't let me open it. The Open window is set to show all files but it isn't showing all files.
Does anyone know what I need to do to fix this problem?
Can you play that same video? If not, maybe you need to install a codec for that video.
Yeah it plays fine on my computer. The reason I am putting it in the program though is to convert it to another format. You see the production people I need to send it to are saying that file and another one I have sent them is corrupted. I'm not sure how they are corrupted if I can view them though. So I thought if I change it to another format that might help.
Is there some way of scanning a video to find out what problems may be occurring? -
you can try gspot and mediainfo for more information
what mediaplayer are you using on the work pc that plays these files normally?
Maybe the IT guys goofed up or install got corrupted. Try running avidemux off a usb stick or download to your desktop (there is an installed version, and one version that runs separately), or do you need permission for the work pc to do that? -
Both videos play fine with Windows Media Player 9 and Media Player Classic. Thanks for the links! I'll have a go running it off the USB stick.
You probably can't download any other programs or converters either. Try downloading to a desktop or different location
You will probably need your IT/tech guys to give you permissions or poke a hole in the firewall (open some ports)
You might have restrictions placed on avidemux too, and/or other programs by your techies
avidemux question ....
By zero7404 in forum Video ConversionReplies: 6Last Post: 25th Mar 2012, 09:01 -
Avidemux aspect ratio question [from newbie to Avidemux]
By ANOther1676 in forum EditingReplies: 1Last Post: 20th Jan 2012, 20:07 -
AVIDemux question
By imhotepiii in forum EditingReplies: 8Last Post: 16th May 2011, 16:07 -
Avidemux question...
By Immortal25 in forum Video ConversionReplies: 13Last Post: 15th Oct 2010, 09:18 -
AviDemux To YouTube Question
By hech54 in forum Video Streaming DownloadingReplies: 8Last Post: 30th May 2009, 13:42
