Hi i tried to encode at the standard 1150 kps for my videos but whenever they are done, i check and see that they are only encoded at like 1100 or 1000 kps...so when i burn them onto vcds their is a sync problem cuz the bitrate isn't 1150 like its suppose to be..
When you bot up TMPG load the ntsc or pal VCD template prior to encoding. It sounds as if your encode settings are off....
~~~Spidey~~~
"Gonna find my time in Heaven, cause I did my time in Hell........I wasn't looking too good, but I was feeling real well......" - The Man - Keef Riffards
Should i put average bitrate or max bitrate in 2pass encoding mode?
By tendra in forum Video ConversionReplies: 28Last Post: 11th Nov 2011, 07:38 -
TMPGenc Authoring 4: problem with incorrect bitrate
By bpchia in forum Authoring (DVD)Replies: 5Last Post: 3rd Aug 2011, 01:53 -
TMPGENC encoding problem
By whschlebaum in forum Video ConversionReplies: 0Last Post: 26th Apr 2011, 22:22 -
DVD Shrink and TMPGENC bitrate problem
By haddockd414 in forum DVD RippingReplies: 2Last Post: 12th Mar 2008, 12:31 -
Problem with bitrate and file size when encoding with XviD
By megakoolkid in forum Video ConversionReplies: 13Last Post: 25th Jun 2007, 17:12
