I just had a Western Digital WD1200B006 external firewire/usb drive fail last night. Fortunately, it was not the hard drive itself, but either the power or the controller card inside. I was able to take the drive out and connect it internally and all was well. Whenever I leave the house, I like to disconnect the drive and hide it in the event of a burglary.
What is a good portable drive, i.e. one that won't self destruct from being turned off and unplugged a lot? This particular drive didn't have an on/off button so maybe that had something to do with its eventual failure, not sure..
I put mine together out of components so I can choose the drives. While I've had one drive failure (out of 16 cases), the chassis has never failed.
http://www.newegg.com/Product/Product.aspx?Item=N82E16817182144&cm_re=rosewill_enclosu...-144-_-Product"Quality is cool, but don't forget... Content is King!" -
Did some research and learned that the "portable" drives actually don't even use power supplies. So that's probably the way to go. I'm not using that machine for any video capturing, just regular business stuff so the 5400RPM shouldn't be an issue.
There you go...
Seagate Expansion 2.0 TB USB 2.0 Desktop External Hard Drive
By kyrcy in forum ComputerReplies: 7Last Post: 30th Nov 2011, 12:03 -
External Hard Drive to TV USB
By codeseven in forum Newbie / General discussionsReplies: 6Last Post: 1st Nov 2011, 11:10 -
Pioneer DVR 550 and external USB hard drive
By jackdup in forum DVD & Blu-ray RecordersReplies: 12Last Post: 5th Jul 2010, 15:47 -
Slightly OT -- Power Supply for External USB HDD used with Portable Device
By GrayStrickland in forum Portable VideoReplies: 2Last Post: 25th Mar 2009, 14:50 -
Picking an external USB drive for backing up- Advice please!
By ahhaa in forum ComputerReplies: 12Last Post: 21st Dec 2007, 18:35
