I'm thinking of getting a capturecart of some sort for my pc.
I was planning on capturing mostly from both PAL and NTSC sources. And the "target" will mostly be VCD... What card, or what kind of card is the best? I have a PIII-500 now, but planning an upgrade soon...
Please help me with suggestions...
Personally I think the Data Translation Broadway Pro gives you the best of the VCD costing $499-$799 if you can affort it. But their Tech support is non-existant. So the question is do you want to do a real time MPEG 1 capture or you want to buy a capture card and capture in say AVI and do your VCD encoding offline? and also what is your price range? If you can answer those questions, lot of people can offer you suggestions.
State your budget, please. $50? $200? $4000? More? Less?
As Churchill famously predicted when Chamberlain returned from Munich proclaiming peace in his time: "You were given the choice between war and dishonor. You chose dishonor, and you will have war." -
Yes, we need to have more info....
If you have the drive space (approx. 40 gig = 2 hours) , simply get an analog tuner card (Hauppage WinTV) and cap with VirtualDub w/ Huffyuv codec. Cost 40.00 Then encode to Mpeg offline in TMPG~~~Spidey~~~
"Gonna find my time in Heaven, cause I did my time in Hell........I wasn't looking too good, but I was feeling real well......" - The Man - Keef Riffards -
OK. I only have 20gigs at the time, but as i said i'm planning on an upgrade soon. I can't spend too much money on this, so the price have to be under $500.
i've thougt about the "Dazzle DVC II" ($250)
http://www.accessmicro.com/productinfo.php3?ProductId=ZIN759515
Is this card ok? -
Thet was'nt a good link...
Here is a link to the DVC II
http://www.dazzle.com/products/vidcr2.html
Does this look ok?
Anyone who knows this card? -
I have a Hauppage and after reading extensively about this one, and seeing lots on the Dazzle II, I do believe that the Dazzle II would have been a much better option if I could have a)bought it her in Ozland or b)found an OS supplier that didn't want $200 in freight!
Apparently its quite good. Try a search through here... http://forum.vcdhelp.com/search.php
Capturecard for xbox 360 and record with PC
By ThePie69 in forum Capturing and VCRReplies: 6Last Post: 10th Aug 2011, 21:43 -
What's a good way to capture online video with good quality?
By newtie in forum Capturing and VCRReplies: 4Last Post: 19th Feb 2011, 09:41 -
What are good specs for a high-quality MP4 file? (Will look good on my 40&q
By HarlanPepper in forum Video ConversionReplies: 6Last Post: 11th Feb 2009, 03:18 -
Looking for some good instrumental music that would be good for football.
By ingeborgdot in forum AudioReplies: 8Last Post: 26th Nov 2007, 21:18
