Hello,
Has anyone here ever created a PAL M DVD from a NTSC MPEG2 file? My understanding is that PAL M has a similar frame rate and scan line to NTSC; however the color carrier is different?
If I create a NTSC 16:9 or 4:3 DVD from an MPEG2 file, which was encoded using TMPGEnc XPress 4.0, and send it to Brazil, will it work properly there? If not, what will I need to change within TMPGEnc XPress 4.0 to make a working PAL M DVD?
Thanks in advance!
There are just PAL and NTSC DVDs (without modifications). PAL-M is an analog color TV broadcasting standard. Any NTSC DVD should work in Brazil. Technically, either their DVD players should output PAL-M signal for native TV's, or their TV's should have an NTSC input as well. Anyway, all DVDs manufactured in Brazil are standard NTSC ones.
when Pal dvd has correct Ntsc audio (Pal>Ntsc conver)
By spiritgumm in forum Video ConversionReplies: 15Last Post: 13th Oct 2011, 12:57 -
MPEG2 files - are they just MPEG, or are they either PAL or NTSC?
By ibzomie in forum Newbie / General discussionsReplies: 2Last Post: 3rd Jan 2009, 15:07 -
convert hd pal mpeg2 file to hd ntsc mpeg2 file
By gearo in forum SVCD2DVD & VOB2MPGReplies: 8Last Post: 5th Jun 2008, 01:12 -
converting hd pal mpeg2 to hd ntsc mpegs
By gearo in forum DVD RippingReplies: 1Last Post: 3rd Nov 2007, 18:26 -
NTSC mpeg2 to pal needed
By Caned_and_Able in forum Video ConversionReplies: 1Last Post: 10th Jun 2007, 21:13
