i converted an avi movie to a dvd file using dvd flick. i did not click on ISO file though. so clearly, i have separate video and audio ts folders. the VOB files play well. when i burned the dvd using nero, i added the video ts and it automatically does everything. when burning was done, i played it in a stand alone DVD. however the audio is high pitched which sounded like chipmunks. what went wrong?
The problem is not the burning. You'd get nothing at all, not a subtle change like audio tone.
I don't use DVD flick, so I don't know how automatic it is in making settings, but I suspect either the frame rate, or audio sampling rate are wrong.
Use something like G-Spot to diagnose your VOB files and you might work it out.
-- Hmm , as others have noted, possibly Nero took it on itself to reencode your files.
How long did it take from selecting the files to finish of burn? If it was only a few minutes, probably didn't have long enough to reencode. -
i tried using IMGBURN. to no avail though. i changed cd but still no success. here is the IMGBURN log.
I 14:25:57 ImgBurn Version 2.5.0.0 started!
I 14:25:57 Microsoft Windows Vista Home Premium Edition (6.0, Build 6001 : Service Pack 1)
I 14:25:57 Total Physical Memory: 1,039,192 KB - Available: 245,176 KB
I 14:25:57 Initialising SPTI...
I 14:25:57 Searching for SCSI / ATAPI devices...
I 14:25:59 Found 1 DVD±RW/RAM!
I 14:28:56 Operation Started!
I 14:28:56 Source File: C:\Users\cynthia\Documents\dvd\dvd.iso
I 14:28:56 Source File Sectors: 2,271,200 (MODE1/2048)
I 14:28:56 Source File Size: 4,651,417,600 bytes
I 14:28:56 Source File Volume Identifier: DVD Video
I 14:28:56 Source File Volume Set Identifier: 3B3A6D6F0022A7C0
I 14:28:56 Source File Application Identifier: IMGBURN V2.4.4.0 - THE ULTIMATE IMAGE BURNER!
I 14:28:56 Source File Implementation Identifier: ImgBurn
I 14:28:56 Source File File System(s): ISO9660, UDF (1.02)
I 14:28:56 Destination Device: [1:1:0] MATSHITA DVD-RAM UJ-85JS F100 (E
(ATA)
I 14:28:56 Destination Media Type: DVD+R (Disc ID: OPTODISC-OR8-00) (Speeds: 2.4x)
I 14:28:56 Destination Media Sectors: 2,295,104
I 14:28:56 Write Mode: DVD
I 14:28:56 Write Type: DAO
I 14:28:56 Write Speed: MAX
I 14:28:56 DVD+R Reserve Track: No
I 14:28:56 Link Size: Auto
I 14:28:56 Lock Volume: Yes
I 14:28:56 Test Mode: No
I 14:28:56 OPC: No
I 14:28:56 BURN-Proof: Enabled
I 14:28:56 Filling Buffer... (40 MB)
I 14:28:57 Writing LeadIn...
W 14:29:08 Failed to Write Sectors 768 - 799 - Reason: Power Calibration Area Error
W 14:29:08 Retrying (1 of 20)...
W 14:29:08 Retry Failed - Reason: Power Calibration Area Error
W 14:29:08 Retrying (2 of 20)...
W 14:29:08 Retrying (3 of 20)...
W 14:29:08 Retrying (4 of 20)...
W 14:29:08 Retrying (5 of 20)...
W 14:29:08 Retrying (6 of 20)...
W 14:29:08 Retrying (7 of 20)...
W 14:29:08 Retrying (8 of 20)...
W 14:29:08 Retrying (9 of 20)...
W 14:29:08 Retrying (10 of 20)...
W 14:29:08 Retrying (11 of 20)...
W 14:29:08 Retrying (12 of 20)...
W 14:29:08 Retrying (13 of 20)...
W 14:29:08 Retrying (14 of 20)...
W 14:29:08 Retrying (15 of 20)...
W 14:29:08 Retrying (16 of 20)...
W 14:29:08 Retrying (17 of 20)...
W 14:29:08 Retrying (18 of 20)...
W 14:29:08 Retrying (19 of 20)...
W 14:29:08 Retrying (20 of 20)...
W 14:30:24 Retrying (21)...
W 14:30:24 Retry Failed - Reason: Power Calibration Area Error
W 14:30:25 Retrying (22)...
W 14:30:25 Retry Failed - Reason: Power Calibration Area Error
W 14:30:26 Retrying (23)...
W 14:30:26 Retry Failed - Reason: Power Calibration Area Error
W 14:30:26 Retrying (24)...
W 14:30:27 Retrying (25)...
W 14:30:27 Retry Failed - Reason: Power Calibration Area Error
W 14:30:27 Retrying (26)...
W 14:30:28 Retrying (27)...
W 14:30:28 Retry Failed - Reason: Power Calibration Area Error
E 14:30:37 Failed to Write Sectors 768 - 799 - Reason: Power Calibration Area Error
I 14:30:37 Synchronising Cache...
W 14:30:41 User opted to skip the 'Close Track/Session/Disc' functions.
E 14:30:41 Failed to Write Image!
E 14:30:41 Operation Failed! - Duration: 00:01:45
I 14:30:41 Average Write Rate: 0 KB/s (0.0x) - Maximum Write Rate: 0 KB/s (0.0x)
I 14:33:39 Operation Started!
I 14:33:39 Source File: C:\Users\cynthia\Documents\dvd\dvd.iso
I 14:33:39 Source File Sectors: 2,271,200 (MODE1/2048)
I 14:33:39 Source File Size: 4,651,417,600 bytes
I 14:33:39 Source File Volume Identifier: DVD Video
I 14:33:39 Source File Volume Set Identifier: 3B3A6D6F0022A7C0
I 14:33:39 Source File Application Identifier: IMGBURN V2.4.4.0 - THE ULTIMATE IMAGE BURNER!
I 14:33:39 Source File Implementation Identifier: ImgBurn
I 14:33:39 Source File File System(s): ISO9660, UDF (1.02)
I 14:33:39 Destination Device: [1:1:0] MATSHITA DVD-RAM UJ-85JS F100 (E
(ATA)
I 14:33:39 Destination Media Type: DVD-R (Disc ID: SONY16D1) (Speeds: 1x, 2x, 4x, 8x)
I 14:33:39 Destination Media Sectors: 2,298,496
I 14:33:39 Write Mode: DVD
I 14:33:39 Write Type: DAO
I 14:33:39 Write Speed: MAX
I 14:33:39 Link Size: Auto
I 14:33:39 Lock Volume: Yes
I 14:33:39 Test Mode: No
I 14:33:39 OPC: No
I 14:33:39 BURN-Proof: Enabled
I 14:33:39 Filling Buffer... (40 MB)
I 14:33:50 Writing LeadIn...
I 14:34:57 Writing Session 1 of 1... (1 Track, LBA: 0 - 2271199)
I 14:34:57 Writing Track 1 of 1... (MODE1/2048, LBA: 0 - 2271199)
W 14:37:00 Failed to Write Sectors 131744 - 131775 - Reason: Tracking Servo Failure
W 14:37:00 Retrying (1 of 20)...
W 14:37:08 Retry Failed - Reason: Cannot Write Medium - Incompatible Format
W 14:37:08 Retrying (2 of 20)...
W 14:37:08 Retrying (3 of 20)...
W 14:37:08 Retrying (4 of 20)...
W 14:37:08 Retrying (5 of 20)...
W 14:37:08 Retrying (6 of 20)...
W 14:37:08 Retrying (7 of 20)...
W 14:37:08 Retrying (8 of 20)...
W 14:37:08 Retrying (9 of 20)...
W 14:37:08 Retrying (10 of 20)...
W 14:37:08 Retrying (11 of 20)...
W 14:37:08 Retrying (12 of 20)...
W 14:37:08 Retrying (13 of 20)...
W 14:37:08 Retrying (14 of 20)...
W 14:37:08 Retrying (15 of 20)...
W 14:37:08 Retrying (16 of 20)...
W 14:37:08 Retrying (17 of 20)...
W 14:37:08 Retrying (18 of 20)...
W 14:37:08 Retrying (19 of 20)...
W 14:37:08 Retrying (20 of 20)...
E 14:37:28 Failed to Write Sectors 131744 - 131775 - Reason: Tracking Servo Failure
I 14:37:29 Synchronising Cache...
W 15:13:10 User opted to skip the 'Close Track/Session/Disc' functions.
E 15:13:10 Failed to Write Image!
I 15:13:10 Exporting Graph Data...
I 15:13:10 Graph Data File: C:\Users\cynthia\AppData\Roaming\ImgBurn\Graph Data Files\MATSHITA_DVD-RAM_UJ-85JS_F100_SATURDAY-SEPTEMBER-26-2009_2-33_PM_SONY16D1_MAX.ibg
I 15:13:10 Export Successfully Completed!
E 15:13:10 Operation Failed! - Duration: 00:39:31
I 15:13:10 Average Write Rate: 1,744 KB/s (1.3x) - Maximum Write Rate: 2,860 KB/s (2.1x) -
1) That MATSHITA drive is JUNK.Originally Posted by jekkherg
2) If the VOB files play well as you said...it was NERO that caused the "chipmunk audio"
by re-encoding something that it shouldn't have. Nero didn't just "burn" your material...it changed
something in the process.
3) Optodisc DVDRs...JUNK
4) Sony DVDRs....JUNK
Most quality DVD burners....combined with ImgBurn...can get good burns
from junk DVDRs....you have a junk burner using junk media...there is no nice way to say it....sorry.
You also need to take control of the burn speed. DO NOT allow ImgBurn or any other program to burn at
MAX speed....especially with your burner and your choice of DVDR brands. -
you must have copied JUNK and pasted several times to save time.
thank you for the much needed reply though. will see to it that hardware change will be sought.
thank you again! -
Sony DVD-R is not junk, if made in Taiwan.
See www.nomorecoasters.com
Malaysian Sony, yeah, not too hot.
Laptop drive? Yeah, not so hot.
Nero is not really suggested either.Want my help? Ask here! (not via PM!)
AVStoDVD Making Chipmunk High Speed Audio
By theWallflower in forum AudioReplies: 9Last Post: 6th Sep 2012, 14:14 -
additional audio decoder needed to play this soundtrack-Dolby AC3 Audio
By tbone1209 in forum AudioReplies: 6Last Post: 19th Jun 2011, 20:58 -
Capturing Mini DV gives Chipmunk Audio.....why?
By fsa3011 in forum Capturing and VCRReplies: 18Last Post: 20th Jan 2009, 18:22 -
Chipmunk-sound-like problem...
By aruwin in forum Video ConversionReplies: 3Last Post: 28th Nov 2007, 03:34 -
DVD to ipod sounds like a chipmunk no matter how I convert
By nukular in forum ffmpegX general discussionReplies: 3Last Post: 11th Sep 2007, 18:00
