can anyone guide me to good software that will quickly convert WMV to AVI (or MKV) , ive tried AVI4PSP or whatever its called but i couldnt get it too work
any help appreciated - it so i can play a WMV file on my HDTV that has USB and HD DivX
thanx
I guess you mean xvid4psp. Try also handbrake, winff, format factory or virtualdub with the wmv plugin.
And if they wont work then give us more details about the wmv, use mediainfo and open the wmv, change view->text and copy and paste the info here. -
I think the easy, powerful and universal thing is to use AVISynth to open WMV
then open this .avs script in virtualdub and convert it to xvid. Should work with all other video format of source video too. Probably you need to have ffdshow installed to decode video.Code:DirectShowSource("yourfile.wmv") -
You might try Any Video Converter Free Version. Use the 'Customized AVI Movie' for best choices for output format.
AVI or WMV?
By NyTeHaWk in forum Video ConversionReplies: 3Last Post: 3rd Jan 2011, 18:34 -
.wmv to .avi
By cyberlion in forum Video ConversionReplies: 7Last Post: 11th Oct 2010, 16:37 -
Avi to WMV
By ichigo15 in forum Video ConversionReplies: 5Last Post: 20th Aug 2008, 18:18 -
.WMV to .AVI
By korki696 in forum ffmpegX general discussionReplies: 2Last Post: 15th Jun 2008, 22:36 -
WMV to AVI?
By hipatuga1 in forum Video ConversionReplies: 2Last Post: 5th May 2007, 09:13
