I'm totally new to video editing. All I want to do is cut about 14 minutes out of the middle of a 1 hour MP4 video file with little loss/degradation and a smaller output file than input file.
I know I'm going to lose something because I'm starting with compressed audio and video inside an MP4 container.
According to MediaInfo, here's what I'm starting with:
_______________________________________________
General
Complete name : C:\Documents and Settings\BlahBlahBlah.mp4
Format : MPEG-4
Format profile : Base Media / Version 2
Codec ID : mp42
File size : 91.9 MiB
Duration : 59mn 5s
Overall bit rate : 217 Kbps
Encoded date : UTC 2009-09-23 13:14:31
Tagged date : UTC 2009-09-23 13:14:31
Video
Format : AVC
Format profile : Baseline@L1.3
Format settings, CABAC : No
Format settings, ReFrames : 6 frames
Codec ID : avc1
Duration : 59mn 4s
Bit rate mode : Variable
Bit rate : 117 Kbps
Maximum bit rate : 480 Kbps
Width : 320 pixels
Height : 240 pixels
Display aspect ratio : 4:3
Frame rate mode : Constant
Frame rate : 14.985 fps
Resolution : 24 bits
Colorimetry : 4:2:0
Scan type : Progressive
Bits/(Pixel*Frame) : 0.102
Stream size : 49.5 MiB (54%)
Writing library : x264 core 65
Encoding settings : cabac=0 / ref=6 / deblock=1:0:0 / analyse=0x1:0x111 / me=umh / subme=6 / psy_rd=1.0:0.0 / mixed_ref=0 / me_range=16 / chroma_me=1 / trellis=0 / 8x8dct=0 / cqm=0 / deadzone=21,11 / chroma_qp_offset=-2 / threads=12 / nr=0 / decimate=1 / mbaff=0 / bframes=0 / keyint=90 / keyint_min=25 / scenecut=40(pre) / rc=crf / crf=26.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / ip_ratio=1.40 / aq=1:1.00
Tagged date : UTC 2009-09-23 13:14:38
Audio
Format : AAC
Format version : Version 4
Format profile : LC
Format settings, SBR : No
Format settings, PS : Yes
Codec ID : 40
Duration : 59mn 5s
Bit rate : 98.2 Kbps
Maximum bit rate : 120 Kbps
Channel(s) : 2 channels
Sampling rate : 44.1 KHz
Resolution : 16 bits
Stream size : 41.5 MiB (45%)
Encoded date : UTC 2009-09-23 13:14:35
I've got ffdshow and the Gabest splitter. I use them to watch MP4s with Winamp. I don't know how to use them for video editing.
I tried to do the edit with VideoPad (free) but didn't see either AVC or AAC as available output codecs. I ended up with an AVI file with MP3 audio and XVID video that was about 3 times bigger than the unedited file.The XVID was 15fps and 320x240 pixels x 24 bits. The audio was 112 Kbps CBR.
I've got VirtualDub but don't know what codec to get in order to make it open my MP4.
Many TIAs for suggestions from people who reply.
Have you tried Mp4Cam2AVI (a free conversion program)? You can select the video format from compressed to non compressed and the same with audio - pcm or mp3 etc. I use it for the files from my Sanyo HD1000.
CLI to mux/merge MP4 video and AAC audio?
By RogerTango in forum Video ConversionReplies: 8Last Post: 13th May 2013, 16:43 -
Editing MP4 files with H.264 (AVC) video and AAC audio
By Ahari in forum Newbie / General discussionsReplies: 4Last Post: 16th Apr 2012, 17:30 -
Render settings questions for MainConcept/AVC/AAC (*mp4) in Sony Vegas
By vid83 in forum EditingReplies: 10Last Post: 22nd May 2011, 03:55 -
Flash with high quality video (MP4 with H264 video and AAC audio)
By Baldrick in forum User guidesReplies: 49Last Post: 19th Mar 2010, 10:05 -
youtube FLV video with h264 (x264) and/or aac (mp4) audio
By wiseant in forum Video ConversionReplies: 1Last Post: 26th Oct 2007, 17:49
