I'm currently transferring a VHS tape to an .avi file on my computer, the only problem is that VirtualDub is interlacing it. I would like to de-interlace it so it looks like the original VHS tape. I found a program called "TMPGEnc DVD Source Creator" which de-interlaces and reduces noise levels perfectly for me. I only have one problem, it outputs the file in video sizes I don't want to use. (352X240, 352X480, 480X480, 720X480) I want to keep it at 640X480. Anyone have any suggestions as to a comparable de-interlacer and noise reducer like TMPGEnc DVD Source Creator? Thanks a lot in advance!
	"Deinterlace Area-Based" in VirtualDub works pretty well.
 Several more options in AVI Synth.
 None of these advanced filters are really "better" than others, just different.
 All are better than simple methods, like drop-frame or blend.Want my help? Ask here! (not via PM!)
	MasterOfPuppets: Please change your signature image, smaller and no animation. https://forum.videohelp.com/topic124514.html
	The best deinterlacer currently is AviSynth's TempGaussMC_beta1(). Samples:
 https://forum.videohelp.com/images/guides/p1934885/stockholma_0-520_q3_yadif_mvbobmod_t...mca4_tdtmm.avi
 It's also the slowest. About 1/50 the speed of the lesser algorithms.
	Yes, you've found one little detail where TempGaussMC did worse than the others. TempGaussMC also smooths out some of the noise (which I consider a bad thing) and that has caused the thin portion of the post to blend into the water in the background. But the others look much worse overall with flickering jagged edges all over the place. Note especially the stairs near the bottom of the frame in the second half of the video. No deinterlacing method is perfect and none ever will be.Originally Posted by 1junpei
  Question about HD to SD and interlace>progressive>interlaceBy ayim in forum Video ConversionReplies: 4Last Post: 10th Dec 2009, 13:21
  Procoder PAL adaptive interlace vs virtualdubBy telefunken in forum Video ConversionReplies: 1Last Post: 6th Mar 2009, 04:36
  VHS to DVD, resulting interlace issue on televisionBy Sawood in forum Authoring (DVD)Replies: 6Last Post: 8th Apr 2008, 13:08
  VirtualDub De-interlaceBy Lee82 in forum EditingReplies: 16Last Post: 25th Feb 2008, 19:57
  Using VirtualDub or other program to mass convert?By RedPenguin in forum Newbie / General discussionsReplies: 2Last Post: 17th Dec 2007, 18:18
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
			 Visit Homepage
				Visit Homepage
