Evening All,
I recently burnt a load of AVIs from my camcorder to DVD using DVDFlick and noticed one annoying thing. When the end of a title is reached, the image flickers and shakes for a second or so before the next one starts - viewing the AVIs on the PC doesn't show this, so I assume its something that DVDFlick is doing. I can't see any menu options etc that look like they might control this. Is there anything I can do about it?
Cheers,
Al.
				Results 1 to 14 of 14
	I was afraid that might be the caseOriginally Posted by guns1inger How easy is it to put fading in? How easy is it to put fading in?
 Thanks,
 Al.
	The simplest way would be to wrap a small avisynth script around each clip. Something like
 You would have to change the path in the AVISource() statement to match your movie, and the fade durations to give you what you want.Code:AVISource(c:\movies\movie1.avi).FadeIn(60).FadeOut(60)
 I would use the Avisynth method because it saves you having to re-encode your video before loading it into DVD Flick.Read my blog here.
	Thanks very much for the hint - I will try that out later.Originally Posted by guns1inger
 Al.
	I have a small problem with using AVISynth. I've downloaded it and written a small script (see below), but when I try to load it into DVDFLick it says that the script has no usable video track so can't be loaded. Have I missed something?
 The script:
 AviSource("F:\Videos\From tape\timestamped\camcorder.09-02-13_15-08.00.avi")
 FadeOut(30)
 If I load it into Windows Media Player I get the error 'couldn't locate a decompressor for fourcc dvsd' - is this related to my DVDFlick problem?
 Thanks,
 Al.
	Thanks for that, I have installed Cedocida and the AVS file now loads into Media Player, but I only get sound, no video. If I load it into DVDFlick, then it shows a thumbail of the video as the title, so all seems OK, but I don't have access to a DVD player at the moment to check if it works. I was hoping to play the AVS file somewhere so I can tweak my fade out period. The AVS file won't play in VideoLAN either...Originally Posted by poisondeathray
 Any thoughts?
 Thanks,
 Al.
	no video? did you do the full install of avisynth? IIRC there are some plugins that allow it to be played in MPC / directshow players
 What about opening .avs file in virtualdub?
	A closer look at media player reveals it says 'Error downloading codec' in the status bar very briefly before it starts playing, so presumably my installation of the codec is not quite right. Wasn't much to do, though, I just right clicked on the .inf file and selected 'Install'... It is a full install of AviSynth (or at least I selected all the options, there was no mention of plugins, though).Originally Posted by poisondeathray
 Al.
	avisynth 2.58? use the stable version , not the 2.6 beta
 The install option I was referring to "associate avs with media player 6.4 (play)" , but that should be checked by default
 What happens if you try MPC or MPCHC or vdub, not WMP11?
 If you have ffdshow installed you can enable DV in the vfw configuration (gold icon)
	If I use MPC, it says I may not have the required codecs or filters installed, and then gives this information:
 C:\tmp\video\fadetest.avs::Avisynth video #1
 Media Type 0:
 Video: YV12 720x576 25.00fps
 AM_MEDIA_TYPE:
 majortype: MEDIATYPE_Video {73646976-0000-0010-8000-00AA00389B71}
 subtype: MEDIASUBTYPE_YV12 {32315659-0000-0010-8000-00AA00389B71}
 formattype: FORMAT_VideoInfo {05589F80-C356-11CE-BF01-00AA0055595A}
 bFixedSizeSamples: 1
 bTemporalCompression: 0
 lSampleSize: 622080
 cbFormat: 88
 VIDEOINFOHEADER:
 rcSource: (0,0)-(0,0)
 rcTarget: (0,0)-(0,0)
 dwBitRate: 0
 dwBitErrorRate: 0
 AvgTimePerFrame: 400000
 BITMAPINFOHEADER:
 biSize: 40
 biWidth: 720
 biHeight: 576
 biPlanes: 1
 biBitCount: 12
 biCompression: YV12
 biSizeImage: 622080
 biXPelsPerMeter: 0
 biYPelsPerMeter: 0
 biClrUsed: 0
 biClrImportant: 0
 pbFormat:
 0000: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
 0010: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
 0020: 00 00 00 00 00 00 00 00 80 1a 06 00 00 00 00 00 ........€.......
 0030: 28 00 00 00 d0 02 00 00 40 02 00 00 01 00 0c 00 (...Ð...@.......
 0040: 59 56 31 32 00 7e 09 00 00 00 00 00 00 00 00 00 YV12.~..........
 0050: 00 00 00 00 00 00 00 00 ........
 VirtualDub plays it quite happily, though, does it have its own codec?
 Thanks,
 Al.
  DVDFlick Re-EncodingBy bolintx in forum Authoring (DVD)Replies: 22Last Post: 31st Jan 2016, 17:30
  problem with DVDFlickBy Bavafan in forum Authoring (DVD)Replies: 3Last Post: 16th Sep 2010, 12:29
  need help with dvdflickBy shashgo in forum Authoring (DVD)Replies: 4Last Post: 24th Jul 2010, 01:24
  help with dvdflickBy shashgo in forum Newbie / General discussionsReplies: 5Last Post: 28th May 2008, 06:03
  no subs. using dvdflickBy crashstorm in forum Newbie / General discussionsReplies: 1Last Post: 29th Dec 2007, 11:46
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
